generator light always on
/ generator light always on #1
MillWeld
Gold Member
Durham NC
Ford 641
On my Ford 461 tractor (1958 model, 6 VDC starter) the red gen light is on bright when idling and rather dim when at operating rpm. How do I determine if it is the generator or voltage regulator?
/ generator light always on #2
Check the voltage out of the generator and out of the voltage regulator.
probably a dumb question but ... what voltages should i expect to isolate the source of the problem?
/ generator light always on #4
assume you mean a 641.
full field the unit and then check. IE.. jump bat to field. if lamp goes out at anything over idle, then you could replace the reg. if lamp don't go out, then slip belt off the gen and try a motor test. jump bat to arm and field. should spin real good like a motor.. if it is slow or stalls.. probably time for brushes.. etc.
can always check bat voltage at batter before start, at idle, then mid throttle, then high throttle.
6.2 - 6.3 is a well charged static 6v battery.
7.2 - 7.3 is good charge voltage. 6.3-6.6 should be a very low charge
not.. analog meters are good to use to check this as cheap consumer grade and auto rangers don't like brush noise due to timing windows / sampling rates..
soundguy
oops, yeah, it is a 641.
I took a short circuit to a repair. I figured the generator brushes probably wouldn't fail so quickly so I replaced the regulator with a used one known to be good and the problem was solved. :thumbsup: Thanks for the detailed analysis, Soundguy, I'll hold on to that one.
/ generator light always on #6
hope it helped some.
soundguy
40 Gallon 2 Stage Air Compressor (A64047)
40 Gallon 2 Stage...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2021 PETERBILT 367 (A63569)
2021 PETERBILT 367...
Sun Burst Box Blade (A64047)
Sun Burst Box...
