General Question on Diesels
   / General Question on Diesels #11
You'd like to think that a company like JD could have persuaded DD or Cummins to enter the market with their projected sales of GTs and SCUTs.
Some #'s from last Fall:
Compact Tractor Sales Strong in October Across North America | 217-11-14 | Rural Lifestyle Dealer
For a given hp engine range, I don't think any of those USA #'s are high enough (all manufacturers combined) to distract DD or Cummins from their primary large products. (What I do find weird about those tables is how low 4wd sales are vs. 2wd).
Given the hoops off-road manufacturers now have to jump through emission wise, the numbers have to be pretty large to justify a new engine range.
Rgds, D.
   / General Question on Diesels #12
They must have got it wrong, and mixed up 2wd vs 4wd.
   / General Question on Diesels #13
I don't think any of the classic diesel engine manufacturers are into those small engines, probably they don't want to make cheap engines designed for a relative short life span.
   / General Question on Diesels #14
Small diesel engines have been in use for a long, long time for marine applications...especially for generators and auxiliary power mills on sailing vessels...many are fresh water cooled using sea water heat exchangers...
It's not uncommon to see "get home" PTO applications that allow an on board generator to be belted or chain linked to the main wheel shaft should the main engine fail...
   / General Question on Diesels #15
There are a few small Diesel engines that were made here. We have a 3.0kw Onan generator in our boat that is diesel powered (and wow are the parts expensive!). My son has a Case 1835C skid steer with a 40 hp diesel made by Teledyne. I think the big reason small diesels are made overseas is that fuel is relatively cheap here. There's just not as much of a market for Diesel engines in small sizes here, whereas in much of the world the market for Diesel engines that are appropriate for taxis, small trucks and anything else that needs power is vast. We just throw a gas engine in most everything that goes down the road unless it's big enough to really need the torque and economy of Diesel. The Asians had the design and manufacture of small diesels down to such a degree that to this day, compact JD's have Yanmar engines. Caterpillar's small and medium small engines are Perkins', to mention engines from Europe. The Agriculture and Construction equipment industries have been world wide enterprises for decades, I think US tractor manufacturers just couldn't (and can't) see any good reason to design and tool up to compete in this market because they already had excellent choices they could buy and install in their equipment.
   / General Question on Diesels #16
I'm going to go a different direction then most here;
our diesels where mainly made for trucking, agriculture and construction starting in the late fifties.
Our tractors where replacing horse teams, and we used horsepower as a selling point, as it enabled larger equipment
and more efficiency. Our trucks already had large gasoline engines and those diesels where developed to haul more, faster,
and with less fuel.
When you look overseas there especially the far east there "tractors" two wheel walk behinds where replacing human manual
labor or a single ox or water buffalo in very small fields and often terraced plots so they developed the smaller engines needed for
there equipment, they also didn't have the large road infrastructure that we do and didn't travel at the speed we do.
A considerable difference in application and driving need during the development period of the tractor and it's engine.
When the small tractor started attracting attention in this country it was the foreign manufactures that had the expertise and equipment.
   / General Question on Diesels #17
There are some new (USA) diesel technologies in development. Achates engines (Michigan) makes a two-stroke, opposing-piston diesel. This has 3 cylinders and 6 pistons (2 in each cylinder), two crankshafts, and no head. About 30% more fuel efficient than a traditional four-stroke diesel of the same horsepower, and also has very low emissions. On the question of overseas diesels, it's important to remember that those companies have been making diesels for along time, even more than DD or Cummins. Yanmar has been making diesels since 1912.
   / General Question on Diesels #18
The old british commer trucks had opposing piston engines back in the 50's but I don't know if they were petrol or diesel.
   / General Question on Diesels #19
Its diesel
   / General Question on Diesels #20
I doubt as refined as those described by Mike Madison, didn't realise they were a single crank.
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Dayton 32965 80-Gallon Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
24in pin on tooth excavator bucket (A56435)
24in pin on tooth...
55# ANVIL (A58374)
55# ANVIL (A58374)
