Generac Generator GP7500E Rebuild
/ Generac Generator GP7500E Rebuild #1
monster318
PA
John Deere 318
Good Morning all,
I recently acquired a Generac 7500 Watt generator for $75 that has sat outside for the past few years. The fuel tank was rusted and full of water, and the piston was seized in the cylinder with heavy rust and water damage to the cylinder walls. The generator end was like brand new however, looked like it never had a drop of water in it. I got the cylinder honed clean, all the other parts cleaned up very well. I cleaned the fuel tank out with a muriatic acid and water mix, which worked surprisingly well. I got a new piston, rings, and complete gasket & seal kit for it.
I am ready to begin putting this back together; however Generac doesn't have a tech or service manual online to provide the specs of things like connecting rod cap torque, head bolt torque or valve lash. I contacted Generac via both email and phone call to inquire about this info or a tech manual. They informed me because I am a homeowner and not a certified service location for Generac that they cannot release such information to me.
Really not sure where to go from here, any ideas?
/ Generac Generator GP7500E Rebuild #3
It's possible your Generac unit was not made by Generac... I have a 6500 watt unit and Generac claims by the model number it was manufactured by Briggs & Stratton (For Generac?) and suggests I contact B&S for information.......
IF nothing else I would use "standard" (SAE) torque settings for bolt grade and diameter.... I know it has to be reliable and serve you for long time, but it's not a space shuttle....
Dale
/ Generac Generator GP7500E Rebuild #4
Get me the actual model and serial number off of the tag on the frame and I can look it up. I am an authorized Generac portable dealer. If this is the Rato 420 engine info may be limited.
Thank you. This is the tag on the frame. 0BD085CA-74A9-41C0-B181-CE4DDBA7AD35.jpeg
/ Generac Generator GP7500E Rebuild #6
Generac doesn't list that service manual on the dealer site. I will call my service distributor tech support tomorrow and see if they can find it for me.
/ Generac Generator GP7500E Rebuild #8
There is no direct information for the Rato engine on this model. From what I and my parts distributor/tech support can come up with is use the information for the 426 engine which is .002-.004 valve clearances and 18 lb-ft for the rod bolts,and 30 lb-ft for the head torque.
But wouldn't hurt to double check the standard torque spec by bolt size for comparison.
/ Generac Generator GP7500E Rebuild #9
If you find the emissions plate, you can usually see the actual maker listed. I would have expected the 2-cyl engine on a gen that big.
BTW, I bought a Chinese-made Generac inverter gen a year ago (iX2000), and it failed. Not fixable, since it needed new inverter-rect board. Generac was no help, so I contacted the Chinese factory which made it. They would sell me the board, but wanted to sell me at least 20 of them.
Thank you everyone for the help. I did find the valve clearance spec in the owners manual online, its my fault for not reading that thoroughly. Owners manual says 0.006'' for intake & 0.008'' for exhaust. I will check on the bolt size torque specs for the rod cap and the head bolts. I plan on having this be my rainy day project tomorrow so I will update tomorrow evening hopefully with good news.
Well I would say today was a success. Everything went back together smooth with no major hiccups. Generator started on the 2nd pull and produced electricity!
Thanks again for everyone’s help and input.
Total price including purchase price & parts I am at $221. I believe I still came out ahead even with having to rebuild the engine. The only thing currently not working at the moment is the hour meter but I can live without that for the time being.
B6B48A59-E6BA-4D04-9403-CF1817004FCB.jpeg 392F1079-17B0-442B-BF24-B653C6C1CF65.jpeg 03CB47D3-D9F1-49B0-A63D-CD7011802386.jpeg489EB008-EF83-44C5-9C11-60F18017132A.jpeg736B53C9-2690-4CD3-B44E-EF493039E351.jpegA3DDAD02-F341-417E-8904-E0DF0C81CF9D.jpegF0DEDAF2-EA62-4F29-837D-82A854586186.jpeg
/ Generac Generator GP7500E Rebuild #13
nice job. Ive replaced a few motors on generac standby generators...and thats a 4-6 hour job. Ive never attempted to rebuild one, as im not wanting to be a mechanic again. Also, the time it would take me to do so would not be worth it. Ive talked to some people that have rebuilt the larger 2 cylinder engines successfully......parts are readily available... but i gave up rebuilding engines back in the 1980's when my brother and i rebuilt chevy engines for racing his GTO. i was fed up with grease and bruises. .
/ Generac Generator GP7500E Rebuild #14
Good job on that Chonda engine!
I can see the emissions plate in this photo. You can decode who made it from that.
From the parts diagram for the engine it is a Rato 420 cc engine
72in. Fork Extension (A61572)
72in. Fork...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
2008 GMC 4x4 Ext. Cab 9Ft Flatbed Pickup Truck (A64194)
2008 GMC 4x4 Ext...
UNUSED WOLVERINE RSB72-72" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
