gear speeds?
/ gear speeds? #1
Ginormous
Dayton, Ohio
Yanmar YM2210
Is there a source somewhere that has the speeds achieved in different gears for Yanmar tractors? I thought I remembered seeing this somewhere, but I can't find it. I am personally interested in seeing them for the YM1700 and YM2210...
/ gear speeds? #2
:cool:
/ gear speeds? #3
the speeds for the 2210 are in that parts pdf I sent you. I know the writing is in Japanese but if you just look it over real good I think you can figure out the speeds.
/ gear speeds? #4
On mine they are slow, slower, super slow and ridiculously slow then in creep they are insane slow, undetectable slow and imaginary movement. :laughing:
/ gear speeds? #5
:D
I thought I would never use 1/1. But its ideal for lurching forward on rough ground, sneaking up on a pallet, and adjusting fork height and tilt at the last moment. While standing up ( no access to clutch pedal) to see what I'm doing.
Aside from that use, I can't imagine tilling that slow. It would take weeks.
/ gear speeds? #6
:D
No Need for Brakes either :D
1/1 can also be for those who have only 1 brake or none at all;)
incidentally which is slower, granny gear or turtle slow?:cool:
/ gear speeds? #7
:thumbsup: "imaginary movement" Great description.:thumbsup:
/ gear speeds? #9
On my 186D 1/1 I think that I could get off the tractor, and get a cup of coffee in town, and come back and the plow would not have moved 6 feet.
/ gear speeds? #10
I can recall when I first unloaded my 2000 off the trailer. I wanted to be careful so I put it in 1/1. It hardly moved. WT:confused: never used Low Gear at the Dealer and had me worried until I went through all the gears making sure there wasn't a problem.:confused2:
High End Mini Golf Cart (A64912)
High End Mini Golf...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
5'x8' Metal Plate (A64912)
5'x8' Metal Plate...
2004 POLAR TANK CRUDE PUP TRAILER (A67714)
2004 POLAR TANK...
2000 Mack DM690S T/A 2,000 Gallon Water Truck (A66736)
2000 Mack DM690S...
