gear speeds?
/ gear speeds? #1
Ginormous
Dayton, Ohio
Yanmar YM2210
Is there a source somewhere that has the speeds achieved in different gears for Yanmar tractors? I thought I remembered seeing this somewhere, but I can't find it. I am personally interested in seeing them for the YM1700 and YM2210...
/ gear speeds? #2
:cool:
/ gear speeds? #3
the speeds for the 2210 are in that parts pdf I sent you. I know the writing is in Japanese but if you just look it over real good I think you can figure out the speeds.
/ gear speeds? #4
On mine they are slow, slower, super slow and ridiculously slow then in creep they are insane slow, undetectable slow and imaginary movement. :laughing:
/ gear speeds? #5
:D
I thought I would never use 1/1. But its ideal for lurching forward on rough ground, sneaking up on a pallet, and adjusting fork height and tilt at the last moment. While standing up ( no access to clutch pedal) to see what I'm doing.
Aside from that use, I can't imagine tilling that slow. It would take weeks.
/ gear speeds? #6
:D
No Need for Brakes either :D
1/1 can also be for those who have only 1 brake or none at all;)
incidentally which is slower, granny gear or turtle slow?:cool:
/ gear speeds? #7
:thumbsup: "imaginary movement" Great description.:thumbsup:
/ gear speeds? #9
On my 186D 1/1 I think that I could get off the tractor, and get a cup of coffee in town, and come back and the plow would not have moved 6 feet.
/ gear speeds? #10
I can recall when I first unloaded my 2000 off the trailer. I wanted to be careful so I put it in 1/1. It hardly moved. WT:confused: never used Low Gear at the Dealer and had me worried until I went through all the gears making sure there wasn't a problem.:confused2:
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2002 Haulmark KD7X16WT2 12ft. T/A Enclosed Air Cascade Trailer (A66738)
2002 Haulmark...
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
213101 (A64276)
213101 (A64276)
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
2023 WEILER S350 SKIDDER (A65056)
2023 WEILER S350...
