Gear Range Selector Issues
   / Gear Range Selector Issues #1
Kevee
Suffolk
MF 1547
Hi,
I have a compact MF and recently have not been able to select the tortoise range. The lever moves all the way to the back but it is not registered past the last neutral.
Does anyone have any ideas as to what the issue could be? It is a bit upsetting because it has only done 400 hours.
Thanks,
Kevin
   / Gear Range Selector Issues #2
Model # and a picture may be helpful? Ken Sweet
Hi, I do not have a pic currently but it is a Massey Ferguson 1547 compact tractor with cab.
The pic is of the same model and the gear range is the lever closest to the bottom of the picture, I can move the leaver all the way along the slot in the tractor trim of the wheel arch without an issue.
Thanks,
Kevin
   / Gear Range Selector Issues #4
Thanks,
Kevin
You may want to check the control cable that runs from the lever? Ken Sweet
   / Gear Range Selector Issues #5
Not sure if it’s the same mechanism on your 1547 but on my GC1720 there is a simple mechanical linkage that rotates a shaft that goes into the transmission housing when you move the lever. If you look underneath the fender while moving the lever you should be able to see if it’s a linkage problem.
Hi,
I have managed to take a look and take a pic, effectively the lever is the arm attached to the cylinder going from the top of the picture downwards.
Looking at when the leaver is moved the end of the cylinder moves outwards a little way. Does anyone have the same system, can it be tightened? Would that be what the issue is because if you push it back close to where it is connected to it is still not in gear.
Thanks,
Kevin
   / Gear Range Selector Issues #7
From here it looks like you nave a loose roll pin that is sticking out. Hard to tell from a picture but it looks like the roll pin is supposed to connect the lever mechanism to the shaft and the pin has loosened and may have slipped out to the point it is letting the lever move without moving the shaft.
   / Gear Range Selector Issues #8
ditto on the roll pin, looks like its inched its way out. check it.
   / Gear Range Selector Issues #10
Yup that roll pin is coming out..
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
2007 Detroit Diesel Series 60 14.0L 6-cylinder Diesel Engine (A48081)
2007 Detroit...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
TEST BID LOT (A50775)
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2012 BMW 528i xDrive AWD Sedan (A48082)
2012 BMW 528i...
