gear or hydro
/ gear or hydro #41
/ gear or hydro #42
I am thinking about upgrading my tractor. I mainly mow around 7 acres of pasture and yard I have a gear drive kubota (shuttle shift) and would like to know the pros and cons of the hydro for the jobs I do. With the gear I run low 4 with the hand throtle and just drive. Is it a pain to use the hydro pedals for large cutting areas. Thanks Randy
I have 10 acres of flat pasture--7 of them mowed with the brush hog. I've used a 4-ft hog on a Kubota B7510HST (hydrostatic, 21 hp engine, 4WD) and now use a 6-ft hog on a Mahindra 5525 (54 hp engine, 2WD, gear tranny). I don't notice any real difference in my comfort level either way--mostly because 7 acres is too small to make a difference in that regard.
2022 FORD F-150 (A63569)
2022 FORD F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
SET OF (3) HYDRAULIC HOOKUPS (A63569)
SET OF (3)...
832856 (A61166)
832856 (A61166)
Case Steiger 600S Tractor (A64047)
Case Steiger 600S...
