Gear drive vs hydro
/ Gear drive vs hydro #101
By about now the original (deer755) is so sorry why he opened up this can of worms again. :eek:
Bottom line , "exercise your freedom of choice backed by money in the bank"
JC,:D:D
/ Gear drive vs hydro #102
[and Egon, what has reality to do with much of this discussion? Limiting the exchange to only those with reasonable experience on both geared and HST tractors would eliminate so much colorful opinion-expression based on (well based on ... hmm well it would eliminate a lot of baseless opinions) and reduce the entertainment index of the thread.
/QUOTE]
It would definitely detract from the entertainment I do agree!:D
/ Gear drive vs hydro #103
So what is the typical HP difference, something like a couple percent at most???
No! At the time I was purchasing my L4400, the next closest HST tractor I could afford was over 10hp less. Thats 45 vs less than 35. I don't care who you are, that is significant, and way more than your 'couple percent'. It could be narrower now, I don't know. I understand the difference between an L4400 HSt vs geared is about 2 grand. That's pretty significant too and that 2 grand will take you up into a higher class of tractor.
I'd gladly trade off a couple percent for the distinct advantages of HST.
So would a lot of people if that couple percent and unicorns were real.
...and Egon, what has reality to do with much of this discussion?
Apparently not much when you're allowing for making up a few numbers here, 'couple percent' there.
I need never have seen one, much less used one to know, factually, that with the same dollar I can put more HP on the ground with a geared tractor than an HST bought with the same dollar. Once again, don't need the experience of third degree burns to know that a hot stove will burn you. Some of us are gifted with that type of common sense...others seem to be less fortunate.:D
Pat
That would be a senseless tragedy since it is quite clear that NONE OF US has anything better to do and this has been quite a hoot!
/ Gear drive vs hydro #104
I like both types of transmissions. I can do anything I need to with either of them. The prime advantage of the HST for me is that there is alot less learning time with new employees, and there is alot less potential for damage due to misuse than with gears. Anyone can push a HST pedal back and forth, but someone unused to a clutch will burn it out faster than necessary. The HST will be unharmed. Also, the insurance costs for employees running HST are much lower (here anyway), probably due to the fact that if you fall off of the tractor, it stops. And, I suppose, they are safer for me too...
/ Gear drive vs hydro #106
easy george, most of us are drinking or doing what our wives say... breath deep
the 'pandora radio' is stealing my time, got it hooked to the 600w. Yamaha at the moment.
Gotta go before i start .. well whatever..NO
Just remembered...osheeze
/ Gear drive vs hydro #107
the best thing about EGON is that he's always there for you, isn't he?
man i must be bored. spelling is alot more interesting than what i think..
/ Gear drive vs hydro #108
Well that explains a few things!:D But it just ticks me off. Worked all day long, nothing on TV (who gives a rip about Notre Dame vs BC) and unlike you guys, I cannot have beer....I'm on call.
... breath deep
Can't...can't catch my breath...laughing too hard. And I'm too young to have an excuse for wetting myself.:D
Don't even know what that is. Guess my kids are right about me.
/ Gear drive vs hydro #109
Interesting comparison. My 27.5 pto hp HST tractor is about 5/8th the hp of my TLB 12 speed gear tractor. The TLB is about 9000 pounds where the hst is about 4500. The TLB has a 20 cuft bucket on the front and a 10 cuft bucket on the hoe. The hst has an 8.8 cuft bucket.
Can you guess which one is able to move more dirt in less time? Need a hint? It's ain't the TLB.
Part of that is the 2wd vs 4wd. But a majority is the functionality of the hst being able to go from forward to backward while dumping the bucket and repositioning it for the next go round. It's harder to shift gears, steer clutch and position the bucket all at the same time. Yet, taking out the need for the hand to be on the gear shift and FEL stick makes it possible. (HST). It is also the ability to ease into the pile and exactly match lifting, roll back with forward pressure. It's also having full hydraulic pressure & flow as I ease into said pile. My foot throttle on the gear tractor can give me more flow, but a too fast of ground speed. Some have said they can feather the clutch. Yeah, do that 500 time a day and see how long it lasts...
But some like gears, some like powershift (glideshift) and some like hst. That's why they make multiple types, there is no one perfect transmission for all people for all uses.
/ Gear drive vs hydro #110
I don't think there is any doubt that an HST will move more material in the loader from one point to another than a gear tractor of the same size. And in commercial applications where time is money that would be important.
For how many of us is that a significant issue?
/ Gear drive vs hydro #111
Yet another KILLJOY injecting reality into this thread.
I can and have loaded more dirt per unit of time with my 39 HP HST than 50HP geared tractors with operators having MUCH MORE EXPERIENCE. It sort of confuses the gear heads when I did it. I had to show the owner's manual to one guy who would not believe I only had 39HP.
I think the "old fashioned" machine occupies the operator so much that he feels he is really doing a lot while the HST does more faster with less effort filling a dump trailer, working sand, gravel, or dirt from a to b if a and b are not hundreds of feet apart.
If you have to transport a bucket of material several hundred feet then a larger bucket (on just about any tractor with any tranny might win the day but less than 100 feet between fill and dump and it is tough to beat an HST.
Sorry if this small dose of reality intrudes on anyone's pre or ill conceived hypothetical notions.
I am not on a religious crusade and have no ego at stake regarding what sort of tranny anyone else has as it has no effect on me. Of course I don't care what kind someone else prefers or for what reason real or imagined they prefer it. HST works for me and I have operated geared tractors and found them inferior for my purposes.
Yeah, that's the way I like it uh huh, uh huh!
Pat
/ Gear drive vs hydro #113
Don't let your kids run your artistic motion, George. I don't want to sound like a drone but u gotta set up your own @ pandora
gotta love it
jake
/ Gear drive vs hydro #115
It is for me. I enjoy my time with my family much more than I enjoy seat time in my tractor.
/ Gear drive vs hydro #116
Think about it like this too.. if you have 2 tractors with the same eng hp.. then you can also look at the hst's drawbar hp as compaired to te gear tranny, as well as the pto hp.. etc.
That pump runs continously.. that and the fluid coupling are where the hp go off too.
soundguy
You've got that right, but it is more confusing than what you've just explained.
As you say, there is some loss of HP at the PTO, but not much.
There is no (or trivial) loss of HP at the engine.
But I would assume that engine HP is measured at the flywheel or some point shy of where the wheels contact the ground, which is where it matters and what we never get specs on.
I'd guess, but might be wrong, that given the same engine HP a geared tractor is going to transfer more of that HP to the ground than an HST.
So if I'm right, its not just a simple matter of what your PTO has to turn.
But finally, as it has been stated so many times, the real issue for the vast number of us who do not have unlimited incomes is not how much HST skims HP from any given machine, but how much more HP you can BUY with a geared vs a hydro tractor.
/ Gear drive vs hydro #117
Hey, where is the speedometer take off on a tractor, anyhow? I don't have a speedometer on my little PT425 and I don't believe my old IH had one, either.
depends on the tractor.. some have them off the engine.. some off of a pump.. some off of the alternator.. As you can guess those are usually tach's with a ground speed chart.. or ring on the tach to show ground speed in a gear, at a specific rpm.. etc.
sounduy
/ Gear drive vs hydro #118
I would imagine 'trivial' has different meanings to different people. 1.5hp is 5% of 30hp.. 5% is starting to sound 'significant'.. while ' a couple.. IE.. 2% may not.. etc.. ). I would not want a 5% reduction in my pay, for example ;)
soundguy
I fail to see the implied importance of the difference.
...and Egon, what has reality to do with much of this discussion? Limiting the exchange to only those with reasonable experience on both geared and HST tractors would eliminate so much colorful opinion-expression based on (well based on ... hmm well it would eliminate a lot of baseless opinions) and reduce the entertainment index of the thread.
Pat
/ Gear drive vs hydro #119
Good point.. and goes along with another point you made.. the price diffeence in HST vs (economy) gear.. it's not an insignificant difference.. and as you point out.. can actually buy you a larger gear tractor vs a smaller HST.
Now.. as tot he significant issue.. that is the big variable.. and applies to tasks that you intend to use said tractor on.
For instance.. take me for example... my 2 primary tractors uses are moving material and mowing.. I'd say it breaks down to 20/80.. IE.. 20$ of my time is using a tractor/loader as a powered wheel barrow. or moile crane. 80% of my seat time is mowing.
clearly... having more pto hp fit my bill.. add to that that 2wd was fine for me in pancake flat florida.. tus etting me een more hp.. that let me step into a larger class of mowing machine.. IE.. utility and small ag tractors.. and their mowers.. like 10-15'. that really saved me some time..
For me.. paying for hst, and perhaps 4wd .. while it might have made my loader dutioes cool... the rest of the time I'd be suffering mowing with maybee a ?? 6' mower.. and taking 40% to 150% longer to mow.. etc.
for -me-... the choice ws clear.. buy large 2wd economy gear tractor vs feature encrusted smaller hst 4wd tractor. ( oh yeah.. and get a ( or two or three ) cheap 2wd gear loader tractor too!
soundguy
/ Gear drive vs hydro #120
Here's more killjoy for you... the common 'task' being used here to describe how much 'better' HST's are than gear tractors always gets tossed around as 'loader work'.. IE.. the 39hp hst moving more dirt than the 50hp gear.
Kick that over to a different task just to be fair.
Will your 39hp hst tote a 10' mower? Your 50hp might.. an 8' anyway...
I'll bet that 50hp geard mows more grass than that 39hp hst... Kinda kicks over to that argument N80 was making... money for the hydro kicks you into a smaller tractor.. smaller tractor uses smaller implements.. smaller implements .. in the mowing world, mean less foot of cut... thus.. more time needed due to a smaller mower. ( wow.. this discussion could have lots of permutations.. IE.. throw in used vs new on the gear vs hst.. and the results skew considerably.. IE.. one of my 70 hp 'classic' tractors and a 10' mower probably cost much.. perahps even 'multiples' less than a 39hp hst with a mower correctly sized for it.. looking at a foot cut, per dollar spent... it gets quite interesting.. but I digress.. that's a completely moot tangent to this discussion.. )
Now... all things are not equal... if money wasn't a concern.. and you could get the larger tractor with the hst.. and needed it.. IE.. lots of obstacles or backing up.. then you are throwing a new variable that needs attention into the mix.. and then you get to decide what options are valuable vs cost.. etc.
it's not a straight clear across the board benefit.. but one of cost vs benefit.. whether tangible or percieved.
soundguy
Pat
INTERNATIONAL 674 TRACTOR (A64276)
INTERNATIONAL 674...
John Deere QA Adapter (A64126)
John Deere QA...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
John Deere 637 (A64126)
John Deere 637...
KL480 Ventrac tiller
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
