Gear Box Leak
/ Gear Box Leak #1
garbageman
Orange County, NY
Kubota 7500
My one year old Befco RMM is leaking gear oil. I'm not sure where it is leaking from but the top of the deck is wet. I add a few onces of oil every time I use the mower which I don't mind doing. Should I try a heavier oil?
Thanks,
Ray
/ Gear Box Leak #2
Talk to your dealer, my Befco tillers gearbox started leaking oil out the seal after the 1 year warranty was up. My dealer repaired it for me and either ate the cost or had Befco pay the bill.
/ Gear Box Leak #3
I think it important that you find out where it's leaking from. Adding oil every time may be your problem. You only add oil when it's low. Adding more will cause it to push oil out the filler/breather cap. Clean up the deck well, run it for a while and see where it's coming from. If it's coming out of the filler/breather cap, you need to reduce the amount of oil. Usually you have a filler on top and a level port on the side somewhere. When filling, you open the level port and fill until it runs out at that level. Any more and it's too much. Usually use 90W gear oil, but follow your owner's manual instruction. John
/ Gear Box Leak
John, I'll give the deck a good cleaning and determine where the oil is coming from.....Thanks
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
2011 JAYCO TRAVEL TRAILER (A67714)
2011 JAYCO TRAVEL...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
AMERICAN FORCE & FOUNDRY 10 TON AIR JACK (A67714)
AMERICAN FORCE &...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A65056)
2017 KOMATSU...
2013 Freightliner Cascadia (A68134)
2013 Freightliner...
