GC2310 Bachoe removal.
/ GC2310 Bachoe removal. #1
aesanders
Platinum Member
Alachua County, Florida
LS MT3 42 S HST cab, BCS 830 2 wheel tractor, Gravely Pro-Turn 160 XDZ, John Deere Gator HPX 615e
For those that have this machine, how easy is removing the backhoe?
Does the 3 point hitch stay on all the time unlike the BX machines that require you to remove the 3 point hitch?
/ GC2310 Bachoe removal. #2
Easy, just use the hydraulics to lift it off ( after you remove the pins ) just be sure to connect the two hydraulic hoses after. I did not do this to start with and I had no 3 point action. After reading the manual and hooking up the hoses all was good. Should have read the manual! I only ran the tractor for a couple of minutes so I don't think any damage was done, as I think the hydraulic system would have a relief valve....
Thanks for the respone.
The 3 point hitch stays on the tractor from what I understand. This seems like a better system than the Kubota uses in which you have to remove the 3 point arms when mounting the backhoe.
This is an important feature for me as I will be using a small rotary cutter farly often and will need to pull the hoe off the machine regularly.
About how long does it take to remove the backhoe?
/ GC2310 Bachoe removal. #4
I am using a brush mower as well, actually have not got it yet but it should be in this week, a Massey 1004. Haven't seen to much on it, so i hope it works well.... as far as the time.... around 2-3minutes to take it off, then unfold the 3-pt hitch arms, hook up your implement and give er.....
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
Steel Blasting Shed (A62679)
Steel Blasting...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2014 Ford Expedition SUV (A64557)
2014 Ford...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
