not2old
- Joined
- Oct 16, 2010
- Messages
- 1,695
- Location
- Scotch Creek, British Columbia
- Tractor
- 2010 Massey GC2610TLB
I need to replace the fuel line from the filter under the floor to the injection pump. and would like to remove the floor to make this easier. If I disconnect the hydraulic lines between the couplings and the loader control will I have to do any sort of bleeding or special procedures when I reconnect them? Replacing the line without removing the floor is doable but would be much easier and I'd be more sure of the quality of the work if I remove it. This is the second leak in this line at about 1000 hours. The first was a few years ago just below the injection pump. All I did was shorten it about an inch and reconnect it. This time it is an inch or two past a filter that I didn't know existed.
Thanks for any advise.
