mgstevens
- Joined
- May 5, 2019
- Messages
- 242
- Location
- Nelson, BC, Canada
- Tractor
- MF GC2410 "Cliffy", JD R72 "Moe Greene"
Wondering what you folks know about the links in the charging system for a GC(2410)? I got my tractor and the charging light was on in the dash (and the battery needed boosting..). I replaced the alternator and the light went out. I tested the battery, which seems like the original factory unit in a 2009 machine (Delkor NX-100-S6MF), and it tested fine. Immediately after installing the new alternator, I multi-meter tested the input to the battery and it was only 12.4V, which puzzled/dismayed me, but the engine has started every time since installing the new alternator - until today.
:grumpy:
I've needed a battery charger - something I've only ever borrowed the few times I've needed it - and so went out and got an "intelligent" charger with a 75A start option. The charger shows the percentage of the battery, which was about 50%, and also shows battery quality (roughly..) and it says this one is OK.
Bottom line is that it looks like the new alternator is not charging the battery. Now I'm looking for potential causes of non-charging, besides the alternator. Electrical ground points, other charging system elements? Along with that, a DIY way to test the new alternator, if anyone knows one. The alternator turned off the charging dash light, but the original meter test and todays results tell the real tale. I have a charging system problem to solve.
Any ideas appreciated.
:grumpy:
