Gator HPX squeaking
/ Gator HPX squeaking #1
sargex595
New York / Vermont Border
John Deere X595
I have a 2005 Gator HPX that has a squeak when you slow up just before you come to a stop. It sounds like it's coming from the rear end. It seems like it squeaks when the rear tires complete a full revolution if that makes sense. You have to be going really slow and just barely turning the wheels. Again, it seems like it squeaks everytime that wheels make a full revolution which makes me think it's coming from either the rear wheels or rear axle. Has anyone had this problem or have a suggestion on where I might start checking? It seems like something just needs lubrication. I don't want to ruin something so any help would be greatly appreciated.
Thanks,
Curt.
/ Gator HPX squeaking #2
Might be the wheel/outer axle bearings? They had an update done to those years ago. I wonder if your was ever done. I would check the driven clutch on the transmission also for cracking around the rivets that hold the sheves to the hubs. They will make a squeaking sound also.
/ Gator HPX squeaking #3
Could be the brakes squeaking. On both our ATV's the brakes squeak sometimes.
It was the brakes. Took the drivers side rear caliper off and the squeak wasn't there. Re-installed and the squeak went away. I was told that there will normally be a high spot that could have caused the squeak. Thanks to all that replied. My main concern was to make sure it's wasn't something major.
Curt.
2018 MERLO TF30-9-11.5 TELESCOPIC FORKLIFT (A63276)
2018 MERLO...
JOHN DEERE S690 COMBINE (A64278)
JOHN DEERE S690...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2004 Harmon Steel Barrel Asphalt T/A Tanker Trailer (A64194)
2004 Harmon Steel...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
