Comparison Gas Tractors
/ Gas Tractors
I think switchgrass or remnant sugarcane would be better than corn ethanol
If going ethanol, I'd look at a ford 8xx or 9xx that was on propane?
I'd also look at biodiesel closer than ethanol...
After I started this thread I started looking closer at biodiesel.
/ Gas Tractors #22
I would be very concerned about running 100% ethanol. The ethanol will destroy the seals in the fuel system of a gas tractor. I am in the parts industry and we will not warranty anything that has been used in over E20. There are no fuel system seals available either OEM or aftermarket that will take 100% ethanol available for any tractor that I am aware of, all the companies only rate to E20. Ethanol will do nasty things to seals, there is a good chance that the tractor will spend more time in the shop then in the field if a high ethanol fuel is run.
/ Gas Tractors
What about 100% biodiesel?
/ Gas Tractors #24
Biodiesel is fine on older non high common rail injection engines. Just replace the rubber hoses with ones that can handle bio. Also when you start using it keep a fuel filter or two handy. Bio will remove all the built up crud in the tank.
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
Tennant 5680 (A64127)
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
