Gas powered winch
/ Gas powered winch #1
rogdan
West Virginia
Farmtrac 360 DTC TLB
I picked up this little gas powed winch with the idea that I could use it for a few things around the farm. I'm looking for advice about putting it into use, such as what size cable, will it work without a fairlead, what kind of rating (pull) do you think I could get from it?
It looks solid and the old B&S engine runs but needs tuned, does anyone have a link about these older engines? Any idea what it was originally built for?
Thanks for any info/suggestions
/ Gas powered winch #3
I'd use 3/8" cable. For general farm use I'd think about mounting it on a carryall and that way you'd have your tractor weight to ground it. If you have a GN ball in your truck you could add an adapter to let it sit/hook on the ball. Something like a keyhole.
Good luck.
/ Gas powered winch #5
/ Gas powered winch
Thanks for the ideas;
So 3/8 wire rope wouldn't be too large for the drum, I didn't think I could get by with larger than 3/16 like ATV winches? I thought about having a hook welded on the back so it could be anchored with a tree saver strap.
Intersting that it could be used like a capstan, I like having that option.
Would this winch likely or not have enough power to pull say 18" logs?
/ Gas powered winch #7
It is hard to tell how much pull it would have without knowing the amount of gear and pulley reductions. It looks like a gear reducer on the engine, pulleys and the winch combined would slow it down a good bit but we need numbers to say for sure.
/ Gas powered winch #8
Well looking at the engine I can say that is a3.5 to 5hp with the 6:1 gearbox I've taken enough apart to know. As for the sheaves can you get us some diameters? And a measurement of the spool. Then we can get a rough line speed and load rating.
/ Gas powered winch
4" at the motor, 13" at the drum
/ Gas powered winch
The power of a winch can be multiplied with sheaves block & tackle style. I'd be more concerned with the strength of the winch frame/bearings/drum shaft. For 18" logs I'd anchor the load sheaves to something other than the winch frame so it would only see a fraction of the load. A 3:1 or 5:1 Z-system used in rope rescue would work well with your winch especially in the capstan mode.
Rope Rescue for Firefighting - Google Books MikeD74T
Very much to learn here, thank you
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
KOMATSU D51PXI-24 CRAWLER DOZER (A65053)
KOMATSU D51PXI-24...
2014 FREIGHTLINER CORONADO 122 SD (A67714)
2014 FREIGHTLINER...
2013 WINSTON AP22024AL-DC EQUIPMENT TRAILER (A66091)
2013 WINSTON...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
