garage lighting
   / garage lighting #1
ch47dpilot
Enterprise Alabama
09 Kubota L3400
looking at building a 40x80 16ft high garage/workshop. Looking for recommendations for lighting. Links to good sites would help to.
   / garage lighting #2
there are so many different options out there at this time, depending on the use of the shop. Stay away from the T-12 lamps, as there being phased out.
8 foot T8 tandem lights work nice, have electronic ballast and cost aprox $60/each including lamps. Personally if i used these id install at (absolute minimum) least 2 in every bay the length of the building and switch each side separately. with 12 total light fixtures youd have aprox 15 FC of lighting (on average). not too bright, but acceptable for most homeowner uses.
to double the foot candle , youd need 3 rows of 8 lights ... that would give you an average of 30 FC. this would use 24 x 140 watts ea = 3,360 watts
Another option is using the new T5 High Output lights. Each fixture uses four 54 watt T-5 lamps, for a 248 watt total per fixture. For 30 FC of lighting you would need 3 rows of 4 light fixtures. These fixtures run aprox $98 each incl lamps. these would use 12 x 248 watts = 2,960 watts/hr
you can also use high bay 400 watt lamps, but i personally hate these fixtures, because they take so long to go fully bright, they lose brightness as the lamps age, and you tend to get more shadows. To get 30 FC of lighting, you would also need to run 3 rows of 4 lights for a total mounting of 12 fixtures. the high bays would use 12 x 400 watts = 4,800 watts/hr
   / garage lighting #3
width and length of shed, and being a shop shed, vs more of a storage / parking lot for the toys....
i would say "some nice bright high up" lights that really brighten the entire area up. but then installing either regular screw in bulb lights, to florescent lights, approx 3 to 5 feet away from the side walls.
for myself, i went with regular screw in light bulbs. for hand tools / bolts / nuts / shelving area. i am only in that area for a bit at a time. and screw in bulbs give quicker instant lights, vs most florescent lights, that take a few minutes to heat up enough to put out full light.
then i use much powerful center lights high up. that flood the entire barn. with nice bright white light. it takes a few minutes for the lights to kick in and get to full brightness. but when i am in the shed for some time working on a project the brighter light works out nice. and then the lights down the sides, help remove any extra shadows.
with above said. if you go with florescent lights down the sides. a "single bulb" setup is good enough for me. with any were from 2 feet to 8 feet space between end to end of next florescent bulb down the sides.
with above said, prefer more lights at lower wattage. and then setting the lights up on a few switches. ya it costs extra for more fixtures, and wiring and switches. but gives me a little bit more control. and lights up places were i want the light. vs cursing at my shadow and not being able to read the 1/8" mark on a tape measure or like.
   / garage lighting #5
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2011 Retesa CT7622 150 Tri-Axle Vacuum Tanker Trailer (A52377)
2011 Retesa CT7622...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
