Garage hacks, adjustments and annoyances.........
   / Garage hacks, adjustments and annoyances......... #121
Yup, that is part of the Rocky Mountains.
Making any headway on the lathe stand?
Not making any progress at all, been having to many sunshiny Saturdays, and my sons been out straight trying to catch up on shingle orders. Last Saturday was a golden opportunity to work on lathe bench but no power so it's kicked ahead a couple more weeks, as of right now the ETA for up and running is Memorial Day weekend, you can mark my words on that, but use chalk................
I'm a inch closer today. I decided on 1/8" steel for the lathe stand top because steel is more versatile and easiest to work with, next might be aluminum, wood, cement, what ever's would come under designated purpose applications.
I called first to the steel place make sure they was open, they said yes but hvae to order over phone, pick it up when I get there cant come in to office, so when I showed up I called again then in a few minutes the lady came out with the sales slip and showed where the steel sheets was. So we go out to the shop and the attendant said you can back the pickup in if you want and I'll lift with the crane, I said it's not that heavy is it, I started to pick up the 4x6 piece and said uh yeah lets back the pickup in.......
   / Garage hacks, adjustments and annoyances......... #124
You're moving right along. What I refer to as, steady by jerks.
Moving right along..... Picture sequence is from right to left, ended up making the bench a wee bit bigger, 26X62.
Had to add about a foot on the back panel, then we slid the bench over to it's location, then set the back panel upright, screwed to wall, tack weld to bottom, un-screw back panel slide back away from wall then weld joint, then clean up and paint, busy day.
Now the next part will be bolting down, framing the lathe bench in so's to keep dust off, but least now it's finally off the floor.
   / Garage hacks, adjustments and annoyances......... #128
Oldpath, man, nice!
   / Garage hacks, adjustments and annoyances......... #129
I like the white background.
   / Garage hacks, adjustments and annoyances......... #130
You guys are doing a great job. That looks really good.
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
MASSAGE CHAIR (A58214)
