Galvanized stock tank as a small pool
/ Galvanized stock tank as a small pool
I had some company the other night.
Me and my wife got in it together.
It was dark so we both went skinny dipping.:D
Pooh Bear
/ Galvanized stock tank as a small pool #23
google earth will have to filter that one :)
soundguy
/ Galvanized stock tank as a small pool #24
Those stock tanks don't have a drain do they? Not that I'm stirring the pot...but...I'm not sure if the little lady would want to take a dip in it if has some mosquito larva wiggling around as you sip wine and eat cheese. Hence Soundguy's goldfish remark. She's not afraid of a few goldfish swimming around between her toes? I hope you don't wash off first before you get in it each day...
However...you could put a little black pond dye in there...so as not to see the larvae, goldfish, salamanders and frogs bumping around in there...then you don't have to worry about even using a filter...not that I'm stirring the pot...
/ Galvanized stock tank as a small pool #25
usually they do have a threaded bung drain.. or at least the 6'ers I got from TSC do.
Yep.. keep a goldfish in there and no more bugs!
soundguy
It has a 1 inch drain plug. A cup of bleach per day should keep any bugs from taking up residence. At about 400 gallons I could change the water occasionally. Maybe every month or so. Instead of Round Up I could drain it, move it out of the way and mow the spot where it sits, then put it back and fill it up with water again. I'm thinking about over the winter coating the bottom of it with Rhino Truck Bed Liner and maybe up the sides a little. Paint the inside with Ford blue implement paint. Should last forever then.
Pooh Bear
/ Galvanized stock tank as a small pool #28
yep.. sounds like a good plan.
soundguy
/ Galvanized stock tank as a small pool #29
She's not afraid of a few goldfish swimming around between her toes?.
get the fish they use for those foot manicures that nibble the dead skin off....although that might not be a good idea in the buff:p
/ Galvanized stock tank as a small pool #30
Funny stuff Skyco...Why didn't I think of that! Just make sure you don't get any piranha. No more Cialis commercials otherwise...
/ Galvanized stock tank as a small pool #31
Has anybody noticed that the chlorine tanks are all made of plastic, even the storage tanks, and valves. A little chlorine might not hurt now, but just one rust spot, and the chlorine will eat away. I have seen a stainless steel spray tank bottom dissolved around the seams. I guess that is where a little bit of chlorine remained.
Every metal spray wand that I have used was destroyed by chlorine. The bleach injectors will corrode if not cleaned after using.
Yes, I really do think chlorine will eat metal.
/ Galvanized stock tank as a small pool #32
Did the same thing - but I had my local Rhino liner dealer come out and spray the inside with RED rhino lining. It was not cheap $950.00 but it is the coolest pool around. Kids love it and the rhino lining will last forever!
/ Galvanized stock tank as a small pool #33
There's only one review for that stock tank on TSC web site. :laughing:
Tractor Supply - Galvanized Round Stock Tank, 6 ft. x 2 ft. customer reviews - product reviews - read top consumer ratings
Technical SpecificationsColor: Galvanized
Dimensions: 6 x 2
Reviews
PoohBear (read all reviews from this user)
Location: Dunlap, TNMakes a great soaking tub.Date: August 25, 2010 I bought one of these to soak in after a hot day working in the yard mowing and such. It's the perfect size for a couple or maybe even 3 people to get in. And even tho I added a small swimming pool filter, the tank is not too big to change the water occasionally. Feels great to come in after a hot day of mowing on the tractor and soaking in a big tub of water.
/ Galvanized stock tank as a small pool #34
Get a "Maybar" liner, Wallyworld sells 'em for like 30 bucks.
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
(APPROX.104), 2X4X8 NO.2 PRIME LUMBER (A60432)
(APPROX.104)...
30ft Highway Trailer Co. Lowboy (A61306)
30ft Highway...
