Galvanized stock tank as a small pool
   / Galvanized stock tank as a small pool
I had some company the other night.
Me and my wife got in it together.
It was dark so we both went skinny dipping.:D
Pooh Bear
   / Galvanized stock tank as a small pool #23
google earth will have to filter that one :)
soundguy
   / Galvanized stock tank as a small pool #24
Those stock tanks don't have a drain do they? Not that I'm stirring the pot...but...I'm not sure if the little lady would want to take a dip in it if has some mosquito larva wiggling around as you sip wine and eat cheese. Hence Soundguy's goldfish remark. She's not afraid of a few goldfish swimming around between her toes? I hope you don't wash off first before you get in it each day...
However...you could put a little black pond dye in there...so as not to see the larvae, goldfish, salamanders and frogs bumping around in there...then you don't have to worry about even using a filter...not that I'm stirring the pot...
   / Galvanized stock tank as a small pool #25
usually they do have a threaded bung drain.. or at least the 6'ers I got from TSC do.
Yep.. keep a goldfish in there and no more bugs!
soundguy
It has a 1 inch drain plug. A cup of bleach per day should keep any bugs from taking up residence. At about 400 gallons I could change the water occasionally. Maybe every month or so. Instead of Round Up I could drain it, move it out of the way and mow the spot where it sits, then put it back and fill it up with water again. I'm thinking about over the winter coating the bottom of it with Rhino Truck Bed Liner and maybe up the sides a little. Paint the inside with Ford blue implement paint. Should last forever then.
Pooh Bear
   / Galvanized stock tank as a small pool #28
yep.. sounds like a good plan.
soundguy
   / Galvanized stock tank as a small pool #29
She's not afraid of a few goldfish swimming around between her toes?.
get the fish they use for those foot manicures that nibble the dead skin off....although that might not be a good idea in the buff:p
   / Galvanized stock tank as a small pool #30
Funny stuff Skyco...Why didn't I think of that! Just make sure you don't get any piranha. No more Cialis commercials otherwise...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
Online Buyers Premium (A55272)
Online Buyers...
Deere 35G (A53317)
Deere 35G (A53317)
PALLET OF CARBURETORS & PARTS WASHER (A58374)
PALLET OF...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
