Gallons per hour....
/ Gallons per hour.... #31
Turbos give you more torque and torque is what gets the work done.
e.meyers, nothing personal, but I think you might be splitting pennies. If you are only going to use your tractor a few times a month for a few hours the fuel costs are negligible. If you really want to save money, find yourself a clean used machine and save thousands.
Low usage would lead me to a NA engine. Nothing likes to sit for a month or more unused.
Uh... HP defined as is the rate of doing work. Torque times RPM is HP.
Just because there is torque does not imply there is useful work being done. Consider a torque wrench registering 100 lb-ft but the nut isn't turning.
One mechanical horsepower of 550 foot-pounds per second is equivalent to 745.7 watts. This is HP definition.
If your engine is raising a weight of 550 lbs a distance of one foot each second (or an equivalent combination) then it is delivering one HP. How much torque is produced to accomplish this relates to gearing and such.
I'm not knocking the importance of torque (I like torque) but lets not let our feelings for torque cloud our understanding of HP.
Pat
/ Gallons per hour.... #32
I burn a gallon per hour in my 3540 when its under serious load, a little more if im running the ac.
Here's some more real life data, no theory involved.
I have a JD 3720 w/cab and have records since it was new (2 yrs). It has a turbo and has averaged 0.6 gph mostly running a 72" mmm, 60" rotary cutter or 59" front snow blower. The AC is on 90% of the time. I don't really need the HP but got a heck of a deal on it and have never regretted it.
My JD 4320 w/OS averages 0.85 gph running a 72" rotary cutter, sprayer, backhoe, 84" BB, and/or FEL type of work.
My M8200 Kubota w/cab and turbo averages 1.1 gph running 8' rotary cutter, sickle bar mower, 8' snow plow, and/or FEL type of work.
The tractors are rarely, if ever, under full load.
/ Gallons per hour.... #33
Pat
Pat, I understand the equation perfectly and you are 100% correct. But, just try mounting a 50 horsepower 250cc 2 stroke motocross engine in your tractor and just see how much "work" it gets done. I guess if you had enough gears to let it wind up.....;)
/ Gallons per hour.... #34
Since they don't test tractors at the university of Nebraska anymore I don't believe in ANY info that the mfg are throwing at us.
Has something changed, as far as I know they still test tractors. It is not required unless selling over 40hp I believe in the great state.
/ Gallons per hour.... #36
After reading this from start to finish, I think everyone is right to the extent that they have stated. NA engines of the same size displacement as TC engines will burn less fuel but only because they have less HP. If you have the same HP in a NA as a TC engine, the TC engine is going to use less fuel when doing the same work because it burns cleaner. .
I have owned NA and TC tractors and never had problems with the TC in a diesel. It is pretty easy to tell a TC diesel engine vs NA by the amount of smoke it is putting out when under heavy load. Black carbon equals unburned or poorly burned fuel. The TC is much more efficient at using the fuel injected to produce HP rather than smoke.
This whole issue aside, the fuel consumption of a CUT should be the least of your concerns. 1 gallon per hour or 2 isnt going to make a major dent in anyones budget. If you can afford a $20K or more tractor that most folks using them for Hobby acres and maybe use 100 hrs per year, 100 gallons of fuel vs 200 isnt a major issue in my opinion. As my old high school principal said when someone asked him how much fuel did his Cadillac use, his answer was "If you have to ask, you cant afford it". I think the same applies to tractors, If you have to be concerned with fuel efficiency between brands,which is minimal, then you likely cant afford the tractor in the first place.
/ Gallons per hour.... #37
Turbo charging a diesel and turbo charging a gas engine are fundamentally different because one is throttled (gas engine) and the other (diesel) is not. This is a bit of a oversimplification but in a gas engine the turbo forces more air and gas into the combustion chamber to allow the engine to product more power. In a diesel the turbo helps to negate the pumping loses allowing more of the power created from combustion to be used.
/ Gallons per hour.... #38
I guess I'm not very scientific...I fill my Kubota's tank when it needs it...Heavy or light useage dictates that.
Don
/ Gallons per hour.... #39
Said another way... Diesels NA or turbocharged have their air intakes wide open all the time and engine output is controlled by the amount of fuel injected. Inject too much fuel (more than there is air to burn) and you make more smoke not more power. Turbos provide more air so you can inject more fuel and burn it. More air and more fuel means more power.
The harder you work the engine the more exhaust gas there is so the faster you spin the turbo and the more air is pumped in by the turbo so you can burn more fuel... lather rinse repeat until diminishing returns dampen the gains. This gives the turbo diesel a wider dynamic range. At light loads it is approximately equivalent to a NA diesel of similar displacement but when worked harder it gets stronger.
I have had a NA Ford F-250 diesel (1984) and turbo Ford F-250 diesel. (2008) The NA version ran out of umph when I tried to take a slide in cab over camper over 11,000 feet on a steep forest service road. In low gear (auto tranny) with full throttle it slowly came to a stop and I had to back down the twisty mountain road to a place I could turn around.
The next year with a 1997 Dodge/Cumins turbo diesel I went up the same road with a larger much heavier camper with a heavy service body on the truck, extra battery banks of golf cart batts, after market fuel tank etc and it would just about wheelie. Way more power than I needed to go up the steep grade mostly due to the turbo which kept the quantity of air going into the engine relatively constant till 9,000 ft or so in altitude and then performance began to taper off with increased altitude whereas the NA engine starts to lose performance as soon as you get above sea level.
I think turbos are a GREAT THING but my Kubota does fine without.
If the engine was not designed for a turbo than adding one will wear the engine out quicker as the crank bearings and such will be under engineered for the added stresses of more torque and HP.
Pat
/ Gallons per hour.... #40
Don
Don, I don't think I'd stop using my tractor if it used 2 gal per hour instead of 1.
I'd just fill it when it got low, like you.
Pat
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A59230)
2007 Oshkosh...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2017 Jeep Patriot 4x4 SUV (A59231)
2017 Jeep Patriot...
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
Honda utv cart (A56859)
Honda utv cart...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
