g18 mower engine losing power
/ g18 mower engine losing power #1
grasshopper1
kubota g18
Hi there i have a kubota g18 rear collection with a high tip, my problem is that the engine is losing power when cutting short grass i have changed the 2 fuel filters it starts fine will cut for a while and all of a sudden it loses power like u were cutting very high grass can anyone help. 2005 is the year of manufacture 18 hp diesel engine
kind regards
grasshopper
engine losing power while cutting g18 diesel
/ g18 mower engine losing power #3
There might be a dual air filter system. I know my old Kubota had it. Check the outer filter, then look inside the housing. I believe inside, a wingnut holds the primary air filter.
only one air filter blew it out the mower stars fine when i engage the blades after about 5 mins it loses power in waves it powers up the powers down
/ g18 mower engine losing power #5
I had some loss of power issues with my G1900 (almost same engine) early after I bought it (used). The local Kubota mechanic recommended adding a some deisel fuel additiive...after a half a tank it was running right again.
I now add a cleaning additive to all my deisel fuel.
Skid steer Backing Plate (A62679)
Skid steer Backing...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
Kubota L295-DT Loader Tractor (A66285)
Kubota L295-DT...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
