g18 mower engine losing power
/ g18 mower engine losing power #1
grasshopper1
kubota g18
Hi there i have a kubota g18 rear collection with a high tip, my problem is that the engine is losing power when cutting short grass i have changed the 2 fuel filters it starts fine will cut for a while and all of a sudden it loses power like u were cutting very high grass can anyone help. 2005 is the year of manufacture 18 hp diesel engine
kind regards
grasshopper
engine losing power while cutting g18 diesel
/ g18 mower engine losing power #3
There might be a dual air filter system. I know my old Kubota had it. Check the outer filter, then look inside the housing. I believe inside, a wingnut holds the primary air filter.
only one air filter blew it out the mower stars fine when i engage the blades after about 5 mins it loses power in waves it powers up the powers down
/ g18 mower engine losing power #5
I had some loss of power issues with my G1900 (almost same engine) early after I bought it (used). The local Kubota mechanic recommended adding a some deisel fuel additiive...after a half a tank it was running right again.
I now add a cleaning additive to all my deisel fuel.
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
(5) Round Grass Hay Bales (A66408)
(5) Round Grass...
3 Brake Drums (A62613)
2022 CAT 289D3 Skid Steer (A62613)
2022 CAT 289D3...
