g18 mower engine losing power
/ g18 mower engine losing power #1
grasshopper1
kubota g18
Hi there i have a kubota g18 rear collection with a high tip, my problem is that the engine is losing power when cutting short grass i have changed the 2 fuel filters it starts fine will cut for a while and all of a sudden it loses power like u were cutting very high grass can anyone help. 2005 is the year of manufacture 18 hp diesel engine
kind regards
grasshopper
engine losing power while cutting g18 diesel
/ g18 mower engine losing power #3
There might be a dual air filter system. I know my old Kubota had it. Check the outer filter, then look inside the housing. I believe inside, a wingnut holds the primary air filter.
only one air filter blew it out the mower stars fine when i engage the blades after about 5 mins it loses power in waves it powers up the powers down
/ g18 mower engine losing power #5
I had some loss of power issues with my G1900 (almost same engine) early after I bought it (used). The local Kubota mechanic recommended adding a some deisel fuel additiive...after a half a tank it was running right again.
I now add a cleaning additive to all my deisel fuel.
2015 Ford Focus Sedan (A59231)
2015 Ford Focus...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
John Deere 1025R (A53317)
John Deere 1025R...
2017 Ford F-450 Auto Crane 5005EH 2.5 Ton Crane Service Truck (A59230)
2017 Ford F-450...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
