Buying Advice G174 crankshaft
/ G174 crankshaft #1
VMCopeland
Paris Texas
Iseki G174,Ford 5000,Kubota B5100
Hello I have an Bolens G174 with a spun rod bearing. And need options can any one help? Thanks VMC
/ G174 crankshaft #2
I just sold my Bolens/ISEKI G-174....maybe it's good thing I did....that's gonna' cost....Len may be able to help out....parts are expensive....I feel bad for you....Ampa
/ G174 crankshaft
I just bought it last week and hope to repair it. I'm trying to find out if this engine was used in other brands or applications. Thank You
/ G174 crankshaft #4
Unless the crank is really destroyed a good well equipped engine repair shop can "spray" the destroyed journal and then turn it down to match the other journals. This would probably be much cheaper than buying a replacement crankshaft. Many times the bearings are a standard size inside diameter and they can find a replacement meant for another application and with minimal modifying you can make it work.
/ G174 crankshaft
Thank You for the info. I completed the tare down yesterday and will give that a try I will post the outcome. VMC
/ G174 crankshaft #6
You can get undersized bearings. turn the crank to the largest size you can get by with. If your crank is too bad, i should have one.
/ G174 crankshaft #7
I just pick up a tx1500f very very very cheap but it has a broken crank. Is there any hope ?
/ G174 crankshaft #8
I can supply you with a crank or an engine.
