Further 7520 questions.
/ Further 7520 questions. #21
/ Further 7520 questions. #22
IH3444 said:
I notice that the NH specs are given at 31.5" out in bucket center....I'll have to look, but I believe that the breakout force of the 18LA loader is 5000# at pivot point.
TC Boomer Utility TC48/55 specs.
http://www.newholland.com/FILES/tbl_s25SeriesText/PDFUpload290/2667/200TL_Loader_specs_071206.pdf
TN series Loader specs.
http://www.newholland.com/FILES/tbl_s25SeriesText/PDFUpload290/2696/800TL_specs_070907.pdf
Looks to me that on the loaders for the TN 75,85,95 the lift at 59" falls short of the ML275 at full height. These NH tractors have the same form factor as the 7520. You cant lift what the 7520 does to full height safely except under very controlled circumstances. My interpretation is the TNs cant lift it to full height at all. From the fast times of the TN loaders it seems that they must have smaller cylinders. That would explain a lot.
larry
/ Further 7520 questions. #23
That's what I was thinking Larry. Have to measure the cylinders, and know the psi the systems are operating at. I believe that NH TN70/75 is 2755psi. Been looking for the Mahindra 6000-7520 system pressure, and need to look at the hydraulic pump output in gals per minute. Thanks for checking in on this for me.
/ Further 7520 questions. #24
Found it for the Mahindras.....11gpm for the 6500, 17gpm for the 7520. Now would like to know psi.:D
/ Further 7520 questions. #25
I just happened to have the working PSI of the 7520, near by. The book says 2690.
/ Further 7520 questions. #26
As Galen says, the tractor relief is set at about 2700psi. The loader relief tho, I believe, [according to KMW spec] is 2450. Lift cyls are 3". 7520 should do 4.9s lift at 2500RPM/17gpm, but is not published as being that fast. Mine will do full lift in 5s flat. Slower than TN loaders, but 3900# to 11' at the pins. Not w/o ballast.
larry
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
LAYMOR SWEEPMASTER 400 (A65643)
LAYMOR SWEEPMASTER...
2013 CATERPILLAR 299D SKID STEER (A65053)
2013 CATERPILLAR...
(2) FIFTH WHEEL PLATES (A65643)
(2) FIFTH WHEEL...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
