Oil & Fuel Fuel usage
/ Fuel usage #1
Anonymous Poster
Epic Contributor
I have a 3010 with 22 Hrs. and running between 2500 and 3000RPM's I figured I'm burning about 1/2 gal. an hour. This seems a little excessive to me . You opinions please
/ Fuel usage #3
That link doesn't appear to be working anymore.
I think this is the new location for it:
<A target="_blank" HREF=http://www.ext.colostate.edu/PUBS/FARMMGT/05006.pdf>http://www.ext.colostate.edu/PUBS/FARMMGT/05006.pdf</A>
/ Fuel usage #4
Same as I use on my BX22 cutting the grass or using the BH.
paul
/ Fuel usage #5
Thanks for the update, Mine was downloded on 6/24/02
seems the same, they just changed it to .pdf
looks a little better printout
JimC
/ Fuel usage #6
That chart looks correct to me. I use about a gallon per hour at PTO speed on my 3010 HST while the chart said 1.15. Close enough for me.
GS
/ Fuel usage #7
<font color=blue>This seems a little excessive to me</font color=blue>
I thought a half gallon per hour would be great. I think I averaged about .7 gallon per hour on my B2710 and was happy with that.
/ Fuel usage #8
Even sounds a bit on the low side to me. For an L3010 running at those RPMs I think I'd be pretty happy with it.
/ Fuel usage #9
A little perspective is in order:
car getting 30 mpg at 60 mph = 2 gal per hour
1/2 gal per hour is pretty good!
/ Fuel usage
HI,
On my B2910, doing a variety of tasks, including a lot of loader work, I was getting roughly 8 hours per 5 gallons. That is pretty much in line with Bird's numbers...
Don't we all wish we could get half-gallon per hour milage from our vehicles on the road!
Bill in Pgh, PA
/ Fuel usage #11
Haven't got a clue as to how much fuel my B7100 uses per hour. Just know that when loaded on the PTO it uses a lot more than for loader or other light work. Usually run at the same RPM most of the time.
Egon
/ Fuel usage #12
1/2 gallon an hour - how do you do that? I've a 3410 (GST), & usually run such at 2100-2400 rpm when brush cutting, leveling, etc. A gallon an hour for heavy work is about right for me.
/ Fuel usage #13
My 3010 GST goes through about 1 gallon an hour when working it. It does seem like it uses more when using the loader even though when I use the loader the RPM's are kept about 2000
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2011 Ford Fusion Sedan (A61574)
2011 Ford Fusion...
(INOP) WHITE 2-180 TRACTOR (A63291)
(INOP) WHITE 2-180...
2022 EZ-GO ELITE...
2004 John Deere 4710 Sprayer (A63688)
2004 John Deere...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
