Oil & Fuel Fuel usage
/ Fuel usage #1
Anonymous Poster
Epic Contributor
I have a 3010 with 22 Hrs. and running between 2500 and 3000RPM's I figured I'm burning about 1/2 gal. an hour. This seems a little excessive to me . You opinions please
/ Fuel usage #3
That link doesn't appear to be working anymore.
I think this is the new location for it:
<A target="_blank" HREF=http://www.ext.colostate.edu/PUBS/FARMMGT/05006.pdf>http://www.ext.colostate.edu/PUBS/FARMMGT/05006.pdf</A>
/ Fuel usage #4
Same as I use on my BX22 cutting the grass or using the BH.
paul
/ Fuel usage #5
Thanks for the update, Mine was downloded on 6/24/02
seems the same, they just changed it to .pdf
looks a little better printout
JimC
/ Fuel usage #6
That chart looks correct to me. I use about a gallon per hour at PTO speed on my 3010 HST while the chart said 1.15. Close enough for me.
GS
/ Fuel usage #7
<font color=blue>This seems a little excessive to me</font color=blue>
I thought a half gallon per hour would be great. I think I averaged about .7 gallon per hour on my B2710 and was happy with that.
/ Fuel usage #8
Even sounds a bit on the low side to me. For an L3010 running at those RPMs I think I'd be pretty happy with it.
/ Fuel usage #9
A little perspective is in order:
car getting 30 mpg at 60 mph = 2 gal per hour
1/2 gal per hour is pretty good!
/ Fuel usage
HI,
On my B2910, doing a variety of tasks, including a lot of loader work, I was getting roughly 8 hours per 5 gallons. That is pretty much in line with Bird's numbers...
Don't we all wish we could get half-gallon per hour milage from our vehicles on the road!
Bill in Pgh, PA
/ Fuel usage #11
Haven't got a clue as to how much fuel my B7100 uses per hour. Just know that when loaded on the PTO it uses a lot more than for loader or other light work. Usually run at the same RPM most of the time.
Egon
/ Fuel usage #12
1/2 gallon an hour - how do you do that? I've a 3410 (GST), & usually run such at 2100-2400 rpm when brush cutting, leveling, etc. A gallon an hour for heavy work is about right for me.
/ Fuel usage #13
My 3010 GST goes through about 1 gallon an hour when working it. It does seem like it uses more when using the loader even though when I use the loader the RPM's are kept about 2000
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 INTERNATIONAL...
2011 BMW 5 Series 528i Sedan (A61574)
2011 BMW 5 Series...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
