Oil & Fuel Fuel system problem..Need help!
/ Fuel system problem..Need help! #1
hazmat1
Everson, Washington
FX18D
I have a FX 18D and I am having a fuel problem of some type. After operating for a little while it dies out. If you let it sit for a bit it will restart but eventually will stop again, it seems to happen faster the second time. I'msure it is a fuel issue of some type but I am not sure where. I have noticed that when this starts to happen the fuel bowl level is down some.
So far I have:
- replaced the fuel filter
- replace the fuel line from the tank to the bowl
- pulled the fuel tank and had it cleaned (there was some dirt in the tank).
Any help anyone can provide would be greatly appreciated.
/ Fuel system problem..Need help! #2
I had a YM1401 that did that. It had the wrong fuel cap. If I opened the cap slightly it would run until I tightened down again.
/ Fuel system problem..Need help! #3
I would agree if all lines are clear then the tank is not venting and creating a vacum. cap or a vent line from tank is most likely the problem
/ Fuel system problem..Need help! #4
I had a YM model that would create a vacuum in the tank if the cap was too tight. Sides would suck in. I just snugged it up enough to keep all the fuel in the tank and all was well.
UNUSED WOLVERINE R-31-G1.5T 1R RIPPER (A62131)
UNUSED WOLVERINE...
UNUSED KJ K1522 PORTABLE RESTROOM (A62131)
UNUSED KJ K1522...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
International 10ft 8 Way Grader Blade (A64047)
International 10ft...
2022 K-Z Sportsmen LE Toy Hauler Camper, VIN # 4EZTU2621N5051599 (A61165)
2022 K-Z Sportsmen...
2015 Bobcat T770 Compact Track Loader (A64047)
2015 Bobcat T770...
