Oil & Fuel Fuel system problem..Need help!
/ Fuel system problem..Need help! #1
hazmat1
Everson, Washington
FX18D
I have a FX 18D and I am having a fuel problem of some type. After operating for a little while it dies out. If you let it sit for a bit it will restart but eventually will stop again, it seems to happen faster the second time. I'msure it is a fuel issue of some type but I am not sure where. I have noticed that when this starts to happen the fuel bowl level is down some.
So far I have:
- replaced the fuel filter
- replace the fuel line from the tank to the bowl
- pulled the fuel tank and had it cleaned (there was some dirt in the tank).
Any help anyone can provide would be greatly appreciated.
/ Fuel system problem..Need help! #2
I had a YM1401 that did that. It had the wrong fuel cap. If I opened the cap slightly it would run until I tightened down again.
/ Fuel system problem..Need help! #3
I would agree if all lines are clear then the tank is not venting and creating a vacum. cap or a vent line from tank is most likely the problem
/ Fuel system problem..Need help! #4
I had a YM model that would create a vacuum in the tank if the cap was too tight. Sides would suck in. I just snugged it up enough to keep all the fuel in the tank and all was well.
LandHonor 30 Gallon Gas Caddy Tank (A62183)
LandHonor 30...
(6) GROUP 31 TOP POST BATTERIES (A63745)
(6) GROUP 31 TOP...
Ingersoll Rand 185 Compressor (A64047)
Ingersoll Rand 185...
Traffic Cones (A62183)
Toro 2300 Top Dresser (A62183)
Toro 2300 Top...
2022 LIUGONG 925E EXCAVATOR (A63569)
2022 LIUGONG 925E...
