Oil & Fuel fuel return line hose clamp
/ fuel return line hose clamp #1
tmar04
YM 276
Where in the world can I get a small hose clamp for the fuel return hose, at the injector connection? Have a pesky leak and can't find a clamp small enough. must be about a 3/16 line, clear vinyl. thanks to all.
/ fuel return line hose clamp #2
The local hardware store should have some. Get the stainless steel threaded ones. They are a little more user friendly.
Or you could come up and search my tool box cause I know there will be one there somewhere. No charge.
Egon /forums/images/graemlins/grin.gif
/ fuel return line hose clamp #3
You probably need a new line. A non-pressurized hose that small shouldn't need a clamp.
/ fuel return line hose clamp #4
I agree, clear vinyl isn't the appropriate material for that line either..........
/ fuel return line hose clamp #5
If worst comes to worst and the leak persists, NAPA has fuel injection hose clamps in a ton of sizes. I use them all the time and they are much more effective then a regular style hose clamp. You have to tell them specifically you want a fuel injection clamp. If all else fails, go to your local car dealership (any make vehicle) and tell them you want a plastic "click lock" clamp for a 3/16 outside diameter hose. They should have one or be able to order one for you. If the parts dept. guy is even remotely helpful, he'll find it.
PM
/ fuel return line hose clamp #6
TMAr04
Try using a small zip wire tye on them i use them on fuel lines on my atvs and my ym2000a.
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
