Fuel issue
/ Fuel issue #1
Jbenoit
79' MF 245 Perkins diesel
Stop arm o ring was leaking at IP. Installed kit. Springs attached on fuel arm. Key on stop arm to the up (outside) position. Bled system. Got fuel to the IP. 1st line completely off, other 2 loose. Turning motor over for 5 or seconds at a time. No fuel to injectors. Running when I parked it! Any help appreciated.
/ Fuel issue #2
I’m assuming u r working on a CAV DPA TOP COVER.??
If yes, u didn’t engage the shut off bar w the nub on the shaft.
/ Fuel issue
You are correct. And the shut off bar your referring to is the horseshoe shaped slide? I assumed the "nub" on the arm just sets in the slide. Does it actually attach to the slide bar.???
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
1991 John Deere 4455 (A64126)
1991 John Deere...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
FORD F750 BUCKET TRUCK (A65054)
FORD F750 BUCKET...
1994 Aeromax Semi Truck (A66285)
1994 Aeromax Semi...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
