Fuel issue
/ Fuel issue #1
Jbenoit
79' MF 245 Perkins diesel
Stop arm o ring was leaking at IP. Installed kit. Springs attached on fuel arm. Key on stop arm to the up (outside) position. Bled system. Got fuel to the IP. 1st line completely off, other 2 loose. Turning motor over for 5 or seconds at a time. No fuel to injectors. Running when I parked it! Any help appreciated.
/ Fuel issue #2
I’m assuming u r working on a CAV DPA TOP COVER.??
If yes, u didn’t engage the shut off bar w the nub on the shaft.
/ Fuel issue
You are correct. And the shut off bar your referring to is the horseshoe shaped slide? I assumed the "nub" on the arm just sets in the slide. Does it actually attach to the slide bar.???
Colombo Twin Master (A64126)
Colombo Twin...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
