fuel filter question
/ fuel filter question #1
Hoobie
New Brunswick Canada
Kubota mx5100 Ford 641
I have a mx5100 with 1700 hours and 10 years old. I change the fuel filter annually. It sits inside a clear plastic cup with a spring that pushes the filter up against an o ring on a pipe that feeds fuel to the engine. Small ring about an inch or so. I was going to replace this ring but it is a pain to get at. And maybe it doesn't matter anyway.
Does anybody replace these? I suspect many Kubota models have the same apparatus.
/ fuel filter question #2
I have the same on my L 3540 when I went to the dealer to buy a couple fuel filters. They asked me if I wanted the big O-ring for the filter seat and the small O-ring for that pipe you’re talking about. I got both didn’t use both didn’t need to. I guess it’s better to have in case you lose them right
/ fuel filter question #3
I never replaced that o ring on my previous L3410, probably not the larger one either. They always looked good and fit well.
Thanks for the replies. Looks good so I will leave it alone.
/ fuel filter question #5
The last filter I bought came with the spring and O-rings. I'm pretty sure it was an aftermarket but can't recall the name. Came off Amazon. I put them in the box for the next change. I have a cabinet with all my machine filters. It's good to have spares on hand and each is marked for the machine.
/ fuel filter question #6
I use Stanadyne Performance Formula additive - it puts any water in the fuel into suspension in microscopic form being consumed by combustion. If the fuel is clean I never have to touch the fuel filter to remove water in the bowl. My oldest tractor has run like this for 26 years and nearly 2,000 hours. I may have changed that filter cartridge once for S's & G's. It doesn't hurt the fuel system or engine.
/ fuel filter question #7
Use to change the NH fuel filter too often. At least when hours came due or just added it to the to do Autumn maintenance list. Filter looked clean. Nothing in the fuel filter holder bowl. But simple and easy to access. The Kubota BX looks to be a pita to change. The opaque plastic filter housing makes visual inspection a no go. IIRC, there are two filters? System looks a bit on the cheapo side. A dedicated filter clear filter housing with a bypass lever and simple replaceable element would have been better.
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
2022 Keystone RV Coleman Camper Trailer, VIN # 4YDTCMN20NH931920 (A65563)
2022 Keystone RV...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
