normde2001
Elite Member
- Joined
- Mar 10, 2002
- Messages
- 4,159
You should be starting at full throttle then backing off after starting at all times.
That's strange. Do you use any two stroke oil or like power service or sea foam in your fuel? Anything for extra lubrication since we have USLD?
Based on my shop manual it would appear all I need to do is put the same number of shims in place as I had with the old pump (2). I purchased new shims from Hoye as well and will verify they are the same thickness as the ones I remove but I expect that to be the case. I just want to verify, is that all that is needed as far as timing on the new pump?
