drunderw
Bronze Member
Good afternoon everyone!
So frustrated. I got the head gasket replaced on the tractor and got about 30 minutes of cutting done and the tractor lost power and shut down. After that it would not start. Temp was right under 190 and it was running great. I have fuel in the filter and in the tank. Thinking maybe an issue getting fuel I pulled in the line off the #1 injector and tried cranking. A small dribble of fuel comes out and then no more as it is turning over. I have a video at the link below showing this. I'm headed back down to unscrew the bleed line at the injector pump to see if I indeed have fuel flowing into it but it appeared so. I read on the Hoye site that I should also at this point drain the diesel, flush the lines and tank, etc to make sure no trash. The filter itself it clean as I replaced it right before the head work and even then it wasn't that bad, just some black specs in it.
Thanks for any feedback!
David
Possible Fuel Pump Issue Yanmar 3110D - YouTube
David
