Fuel cap gasket?
/ Fuel cap gasket? #1
gcp
Gents, is there supposed to be a gasket in the fuel cap? If so my YM 2000's doesn't have it and as a result I am getting overspill. But if there's no gasket there to begin with what else could be the cause for the constant fuel spill?
I am also in need of a couple of the headlight harness pieces that hold the bulbs into place on one end and at the other end connect to the tractor harness via a 3 wire plug. Local dealer wants to sell me the whole headlight assembly, which I don’t need so what’s the best source for such piece parts?
I was able to purchase a box blade last week and perform some badly needed road work at the property. It took me a while to master the task but the drive now looks/feels 100% better. This is my first time at using a tractor and I must say it was more physically hard than I expected but it was also a fulfilling process
See, my drive is rather long, I'd say 300 yards, and badly sloped (down right dangerous at certain spots) so keeping my head turned backward for hours on end did take its toll on the neck/shoulder muscles. I figured out you dig forward and smooth out in reverse, unless there's a better way....
If now I can figure out how to use the scoop effectively I can order a few truckloads of gravel to cover the drive. But that’s for another weekend...
Thanks,
gcp
/ Fuel cap gasket? #2
Well sort of. Directly under the cap there should be a fuel strainer which has a notch to let air into the tank. Here's an old description including a picture I posted.
http://www.tractorbynet.com/forums/yanmar/63884-ym2000-fuel-cap.html
But I think what you are seeing is that the tiny overflow return line from the injectors isn't securely connected to its fitting in the fuel filler neck.
/ Fuel cap gasket?
Thanks California! Matter of fact I saw the strainer being depicted in my newly acquired ebay manuals :D but I thought maybe it was for the 240 alone. I'll go buy one. BTW the overflow tube is tightly in place, I inspected it for leaks before I began studying the fuel cap.
/ Fuel cap gasket? #4
That was definitly the problem with mine.. Got a strainer and havent had a fuel leak since...:D Thanks California....
/ Fuel cap gasket? #5
You say that you are pushing dirt backward. Be aware that you can bend your drag arms. Smooth out in a foward direction only (pulling). I speak from experience.
/ Fuel cap gasket? #6
The head light comes as an assembly . the wires are not sold by themselves unless you can find someone willing to sell them that way.
/ Fuel cap gasket?
Thank you for your valuable inputs guys!!
gcp
/ Fuel cap gasket? #8
gcp,
You control the digging/smoothing by means of the top link on your 3pt. set-up. The more you shorten it, the more it digs. If you lengthen it ( screw it out ) you will rock the blade backwards and you can then smooth or "back blade" forward. Have your gravel truck driver spread the load as he drives and then you can use your box blade to straighten it out.
Looks like you are having a good time with it.
Bruce
/ Fuel cap gasket? #9
When I graveled my driveway, I had two different trucks spread the rock, one drove one direction to lay down the first layer, the second went the other way. When they were done, I didn't even have to blade it, it was so smooth and even. A good truck driver can lay that stuff down perfectly.......
/ Fuel cap gasket? #10
gcp For the headlights I'd just go to NAPA and buy some quick connects and rewire the lights myself.
/ Fuel cap gasket?
Guys, it won't be simple at all to lay gravel over some of my 300 yard drive, especially considering the way some of it is laid out, and the fact that a truckload has to pass over my home made bridge which may not carry its weight. A front end loader would do the trick but I don’t have one so any and all educated suggestions will be greatly appreciated.
Bruce, you are dead on, I figured that out after a while...silly me :)
/ Fuel cap gasket? #12
gcp said:
Guys, it won't be simple at all to lay gravel ... considering ... my home made bridge... educated suggestions will be greatly appreciated.
If you are concerned about the bridge, have them deliver only the last one-quarter of each truckload to the far side of the bridge until the highway side is all delivered. Then maybe send in much smaller trucks? You certainly want them to place the material in its final location, in fact this is essential if all you have is a box blade to level it out.
/ Fuel cap gasket? #13
A more important question is do you have any bass in that pond and when can I come over? Seriously though that looks it will be a tough driveway to get in but oh wow what a location! Envy you.
/ Fuel cap gasket?
California, yours is a good idea, about delivering 1/4 of each truckload across the bridge and up the hill, if that is even possible. Along with the box I also bought a scoop but I've not found it as user friendly as I expected it to be. Certainly not a front end loader replacement.
phatgemi, come on down and fish to your heart's content. There's bass in the pond, and catfish, and bream. I am not a fisherman but the pond is stocked.
I am now in the process of gathering dandelion seeds so I can plant as much as possible around the flat portions of the property for the wild life…and me of course :) Dandelions are so unjustifiably maligned because they are so healthy for us all! Lawn looks over function strikes again!
/ Fuel cap gasket?
The new/used fuel cap, and strainer apear to have solved my fuel tank leaks. I also installed the rear right wheel seal so the hydraulic leak should also be fixed but due to the rain I've not tested the fix yet.
Thanks for all your help guys!
/ Fuel cap gasket? #16
Once you have a ROPS and its seatbelt it is even harder to twist around. I added a mirror and use it continually to see how much I've raised the implement. This avoids many turnarounds. However this one still isn't sufficient for a good view to the rear, since the view is down rather than back, so I still have to twist around to work backward.
I could mount it farther out like a towing mirror, but this tractor is set up for orchard use with everything tucked in as much as possible to reduce snagging the trees.
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
