Oil & Fuel Fuel additive
/ Fuel additive #1
mdbender
Southern Maryland
Yanmar 1610
Getting ready to winterize my 1610 and need suggestions what brand of fuel additive to add to the diesel to prevent gelling. Also does anyone know what size tank this tractor has and how much additive do I need to add to a tank. Thanks
/ Fuel additive #2
hard to know what you want to winterize against when we don't know where you are... Generally speaking, you should change filters, fluids, if in cold climes run 15w-40 oil, and for fuel, ensure clean fuel with powerservice mixed in..
more detail on you environment will undoubteldy give you more info. good luck.
/ Fuel additive #3
Your profile needs to be updated to include your location. You will find that you will get better answers to questions when we know where you are. Your location might/will determine the correct response.
In general, you need to add some Power Service (white bottle) to your diesel fuel, usually 3oz per 5 gallons.
/ Fuel additive #4
It doesn't matter where you are, "Powerservice", or any other brand of diesel additive on your autoparts store shelf will work just fine:rolleyes: . Figure a 5 gal. tank.
2018 Ford Explorer AWD SUV (A66738)
2018 Ford Explorer...
CAT D11R Ripper Teeth (8) (A68134)
CAT D11R Ripper...
2016 Chevrolet Express Shuttle Bus (A66736)
2016 Chevrolet...
2013 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2013 ALLMAND...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
