frontier rmm
/ frontier rmm #1
stormchaser
eastern michigan
new jd 4110/ old ford 1715 4x4
anybody know the differance between frontier 1060 &2060 rear discharge? any pro's con's except mulchability?
/ frontier rmm #2
Not sure about the mowers but the 10 series Boxblades are made by Woods vs the 20 series being made by Worksaver.
I just bought a BB2065 and I am VERY pleased with its heavy gauge construction. It is much beefier than alot of BBs I've seen.
/ frontier rmm #3
Stormchaser,
The difference between those two mowers is that the 1060 is an "economy" line mower. The economy mowers and the 2000 series are both currently manufactured for John Deere by Woods. The main differences are as follows: the 1000 series has a lighter gauge deck, all are rear discharge, they have a slightly less beefy gearbox and pulley hardware, and a slower blade tip speed, so they would not cut quite as well as the 2000 series in deep grass or at higher ground speeds. There is absolutely nothing wrong with the 1000 series decks and they are somewhat cheaper, but if you have the cash, spring for the 2000 series. It is much heavier duty and cuts fantastic. I have a 60" side discharge for my tractor, and the results are amazing for such a big mower and a large tractor. My 2060SD cuts better than my father's 335 garden tractor!!! I do not like the rear d/c mowers because if the grass is wet they blow clumps out the back. They also do not "stripe" quite as well. I have not missed not being able to trim on one side. I have regretted that I did not get the six foot for my tractor. I changed my mind at the last minute because of concerns about mower overhang when hauling. This was a mistake.
John M
/ frontier rmm
Thank's guy's , I'm sure the 10 series will be fine, especially since my last one was a woods. I would upgrade to the 20 series but I have already upgraded just about everything else twice already. Now i'm up to the jd4110 with fel and 72" rb ,& rear mower If the dealer doesn't hurry I will be up to the 4115 which I'm seriously considering. My wife is starting to give me the LOOK. This sight is great, lots of help in decision making. Wish I would have found it when I first started shopping, I would have started at the 4115 and who knows where I'd be now?
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2011 CAT 430E BACKHOE LOADER (A65643)
2011 CAT 430E...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
