front wheels
/ front wheels #11
kenmac,
I don't disagree with what you are saying. I feel the same way. We had a B model JD when I was growing up that was purchased new by my grandfather that had the tricycle front end. I only drove it on flat ground, but you could move the rear tires out a good ways.
Also, if the width of the front end does not make a difference; why would some manufacturers make adjustable front ends? Is it for stability or is it for making sure you don't run over your crops (front wheels travel between rows)? I have never asked that and I am not a farmer, so I am not sure why they would.
Fig
/ front wheels #12
If tricycle front end is more stable, why did the government make the ATV industry stop making 3 wheelers and go to 4 wheelers?
/ front wheels #13
</font><font color="blue" class="small">( If tricycle front end is more stable )</font>
A wide front is way easier to trailer.. 1 less ramp.. unless you are one of those people that use 2 ramps to load a trike.. ( pretty scarry to watch! ).
For dishing the rims.. I guess if your tractor isn't designed for it.. don't do it. same with duals...
I see rears dished for 'safety' here all the time. used to be the standard advice... etc..
Soundguy
/ front wheels #14
I read this thread and then remembered my tractor driving over the years. The pivot point is necessary on a wide front end to keep rear wheel traction on uneven ground. Remenber crossing a terace at an angle. A narrow front end does not need to pivot because all three wills will contact the ground. not so with 4 wide spaced wheels when i crossed a terace with my 4wd with limited pivot and I had to grab for the diff-lock to keep going. Instead of widening the wheels add weight as low as possinle. Rear tires 1/4 or 1/2 full of liquid ballast will really mabe a difference. Tractoring is only good when your drive wheels are in the dirt.
2000 Volvo WG Tri-Axle Dump Truck (A59230)
2000 Volvo WG...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
