Front wheel not rotating when cold.
/ Front wheel not rotating when cold. #1
Dr Dirt
Lebanon Maine
New Holland td 24
I have a TC24D. The left front wheel will not freely rotate when cold. Just wondering if anyone else had this issue, of course there is snow and ice under the wheel and it just slides. I checked the fluid level in the axle and my past experience is that when the axle is warm the wheel runs free. I am guessing that it is either a seal or dirty bearing. I am in southern Maine so it gets pretty cold!! Thanks, Dan.
/ Front wheel not rotating when cold. #2
Of course it could be a seal or dirty bearing but I'd be more inclined to believe somehow water has gotten in there and frozen or you have snow turned to ice jammed up on the outside. Look it over outside for the obvious. If you can get it inside to thaw it will probably work fine.
/ Front wheel not rotating when cold. #3
Jack it up and try to spin the wheel. That should tell you pretty quik where the problem area is.
/ Front wheel not rotating when cold. #4
Another thread on the same issue for a Mahindra:
Thanks! I am 100% sure you are correct!! I placed a torpedo heater near the front end and suddenly the axle began to rotate freely. I am going to drain and look at the oil as soon as it warms up a little outdoors.
/ Front wheel not rotating when cold. #6
Does it have a gear set at the wheel? Did you also check that oil?
Thanks nyone ! Yes,the first thing I did was check the oil level. I am convinced that there is water in the housing. It will free up when the axle housing is heated above 32 degrees. My next step will be figuring out how water crept in. probably new seals. Thanks, Dan.
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
2022 EZ-GO ELITE...
