Front Wheel fell Off
/ Front Wheel fell Off #1
ray_reilly
Central Florida
YM 2000
Yanmar 2000 2WD
Hub still attached to rim , crown nut and pin still on axle
It appears the bearings broke and hub came off, lost dust cover
do you think I could just replace the bearing and dust cover or would I be better off replacing hub and all. Will post pics tomorrow to dark now. Thanks /forums/images/graemlins/confused.gif
Yanmar 2000 2WD
/ Front Wheel fell Off #3
depends on how bad (if any ) damage you did to the wheel itself. You may get by with just new bearings & races.
/ Front Wheel fell Off #4
no damage to rim just started to creep foward loader caught front end before it hit ground or rim
would the bearing and races be available at auto parts store locally? or do I need order them online /forums/images/graemlins/confused.gif
/ Front Wheel fell Off #9
I don't know if auto parts stores would have them or not. I order my parts from fredricks & get them in 1 to 2 days.
/ Front Wheel fell Off #10
/ Front Wheel fell Off #11
WE have a place called Motion Industries in Alabama that either has it in stock or will make any bearing for anything. If there is a number on it most likey a phone call will do, otherwise take it to them and they will match it. There should be such a place near you.
/ Front Wheel fell Off #12
32ft T/A Flatbed Tag Trailer (A66736)
32ft T/A Flatbed...
Luck Now XLR 4750ST (A64911)
Luck Now XLR...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
CAT R450/D9H Ripper Teeth (8) (A68134)
CAT R450/D9H...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A68183)
2006 Ford F-750...
2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
2024 Land Pride...
