front weights
/ front weights #1
GioG
Aynor, South Carolina
1825E Massey Ferguson
Good morning everybody. It's been a couple of months.
So I was wondering if MF makes front ballast weights for my 1825E MF? I noticed that when I apply some weight on the 3 point hitch...the front of the tractor comes off the ground (a little bit) if I need more traction with the 4X4 engaged....I got none.
Thank you.
/ front weights #2
Any front suitcase weight, 35lb size for compact Ford New Holland should work, such as the following:
You could check tractor salvage yards like Southern Global or Wengers
/ front weights #5
I have a L3010 Kubota I wanted weights for. Kubota dealers near me ( 2 of them with in an Hr drive) were not interested in helping. The JD dealer had 3 sizes in stock - 110 lb, 70 lb, and 42 lb. I wanted about 200 lbs so I bought 3 - 70's. Had to modify slightly to go on the tractor weight rack. They cut like butter with a .040 disc. The local Home Depot also carries the 42's.
Just couldn't stand the green :)
/ front weights #7
I put 150lbs worth of weights like that on my previous B8200 to keep the front end down when lifting a 3 point mower.
Keeping them JD green would have looked goofy!
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
John Deere 637 (A64126)
John Deere 637...
(1) UNUSED 31X13.50-15 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED...
300 GALLON FUEL TANK W/MANUAL PUMP (A64281)
300 GALLON FUEL...
2011 Freightliner B2 School Bus (A61573)
2011 Freightliner...
2002 International 9200i Truck (A61307)
2002 International...
