Snow Attachments Front Snow Plow
/ Front Snow Plow #1
pdc
Shennendoah Valley Virginia
Massey Ferguson 360
I'm looking for a good option for plowing snow attached to front of my Massey Ferguson 360 tractor. Considering rigging some king of 3 pt. atachment onto the front to hook my grading blade to. Then incorporating a hydraulic lift and possibly hydraulic side to side pivot. Any experience or suggestions? Thanx
/ Front Snow Plow #2
Are you going to rig up something that will trip the plow (blade) if it hits something solid?
I have rigged a western plow on a Deere 4300 which may give you some ideas.
front plow
/ Front Snow Plow #3
Curtis makes blades that attach to the FEL in place of the bucket. They are easy to attach and remove if you are on level ground. It is a little too substantial for my B2410 and I would sell it to you at a good price if you are within driving distance to Vermont!!!!
I have located a blade that mounts into a 2 inch receiver hitch and I will be mounting a hitch in my bucket for the winter.
/ Front Snow Plow #5
The Curtis runs $1,700 - $2,000 depending on blade length. The dump connections on your FEL controller would be used to angle the blade, unless you have additonal port capability.
(and it does have springs in case you connect with something in the road)
http://www.curtiscab.com/tractor_loader.html
Trailking Detach Semi Trailer (A66285)
Trailking Detach...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2011 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2011 FORD F-550...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
