Front locker available for Kubotas
   / Front locker available for Kubotas #72
What does this do that the standard rear diff lock doesn't do?
This is for the front, which does have a limited slip, but it’s very easily overcome. And the reason it’s easily overcome is because of this cone/spring washer in the second picture. The ”springiness” in that little cone is the only force that applies those friction discs. What I installed is more like a mini Detroit Locker, which replaces the clutch pack and spider gears shown.
“The Torq Locker never technically disengages, but it does allow for wheel spin differentiation so you can turn and steer the vehicle. The Locker achieves wheel speed differentiation through ratcheting. A slight audible click maybe noticeable at low speeds, this is an indication of the locker ratcheting.”
2020 CATERPILLAR 299D3 SKID STEER (A52709)
2020 CATERPILLAR...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
1R CULTIVATOR, 3PT (A52708)
1R CULTIVATOR, 3PT...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
