RSKY
Elite Member
- Joined
- Oct 5, 2003
- Messages
- 2,901
- Tractor
- Kioti CK20S
Was at my mother's house Wednesday when I got a frantic call from my wife. The drain for the washing machine was frozen up and there was water everywhere in the utility room. By the time I got home she had most of it vacuumed and mopped up. We have one drain behind the machine that goes to the septic tank and another that goes to a gravel bed. So I swapped drains and started it up. Ten minutes later we were vacuuming water again. This time I was watching and I could see the water was coming from the front of the machine. Not from behind at the drains. Soooo.....I took off the door leading to the machine drain and filter knowing that I had cleaned it out a couple days before. Everything was as tight as possible and I started the machine again. Water started pouring out from around the filter. I tried to tighten it again but it was as tight as it would go. Took the filter out and got a flashlight and sure enough, there was a small pebble in the back, 1/8" diameter, I measured it. I finally got it out and put the filter bad in. This time when tightened the handle was perfectly horizontal. Before it was at a 45 degree angle. The rock had prevented the gasket from seating properly and let the water run out.
This was on a tile on concrete floor. If it had been on a wood floor or carpet it would have been a disaster.
Just warning everybody to check when draining/cleaning your filters. Make a note of the handle position and make sure it is the same when put back in.
RSKY
RSKY
