Front loader/oil question
/ Front loader/oil question #1
Anonymous Poster
Epic Contributor
I need some help!! I have a Bolens G184/Iseki with a front loader, that works slow very slow and the 3 point is slow also. Both have alot of lifting power. My Questions is?? The hydraulic system/transmission oil is 90 weight. Can/should i change to hydrauic fluid?
Shemp, look in the Yanmar Forum. I asked the question there and a guy responded and siad he changed to hydro fluid and works great now.
Should be on first page. Later
/ Front loader/oil question #3
I have a 1986 Iseki( Bolens G214) with a front end loader and run universal hydraulic, tranmission fluid in it. The tractor manuel says to put in 80-90 gear oil. However, if the tractor has a hydraulic pump in the transmission for the loader you go to hydraulic/ trans fluid which is an upgrade of the basic tractor. The FEL manuel notes this if the hydraulic pump is inside the transmissiom as opposed to a PTO pump. Bolens would import the tractor, paint it up and add american/canadien made FEL and /or, in my case, a back-hoe. Obviously, the manuel is for the basic non hydraulic pump tractor.
