front loader hook-up
/ front loader hook-up #1
hrvata
PA
Magnatrac 4800
I have a Ford Model 1210 tractor and the hydraulic manifold has inlet and outlet ports to connect the spool valve to operate the loader. I connected the outlet of the manifold to the inlet of the valve and the outlet of the valve to the inlet of the manifold. The up valve raises the loader, the down valve continues to raise the loader. Am I connected right?
/ front loader hook-up #2
I am having the very same issue. Did you ever find a solution? I have a Ford 1210 model and I am trying to plumb a Koyker 110 front end loader. I have tried swaping inlet and oulet hoses I have turned the screw on the operating manifold to both positions, and nothing worked. It still raises but will not lower..
/ front loader hook-up #3
are the lines to the loader itself hooded up right? If the loader valve includes regeneration, and the hoses are hooked up wrong I could see it causing this issue. Do the bucket curl functions operate correctly?
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
Landhonor Quick Attach Log Grapple (A66285)
Landhonor Quick...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2016 Isuzu NRR Trash Truck, VIN # JALE5W162G7300782 (A65563)
2016 Isuzu NRR...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
