front loader hook-up
/ front loader hook-up #1
hrvata
PA
Magnatrac 4800
I have a Ford Model 1210 tractor and the hydraulic manifold has inlet and outlet ports to connect the spool valve to operate the loader. I connected the outlet of the manifold to the inlet of the valve and the outlet of the valve to the inlet of the manifold. The up valve raises the loader, the down valve continues to raise the loader. Am I connected right?
/ front loader hook-up #2
I am having the very same issue. Did you ever find a solution? I have a Ford 1210 model and I am trying to plumb a Koyker 110 front end loader. I have tried swaping inlet and oulet hoses I have turned the screw on the operating manifold to both positions, and nothing worked. It still raises but will not lower..
/ front loader hook-up #3
are the lines to the loader itself hooded up right? If the loader valve includes regeneration, and the hoses are hooked up wrong I could see it causing this issue. Do the bucket curl functions operate correctly?
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
Mini Universal Land Plane (A65640)
Mini Universal...
725 Gal Poly Tank on Skid  (A62679)
725 Gal Poly Tank...
2021 UTILITY VS2DX 53x102 T/A DRY VAN TRAILER (A59914)
2021 UTILITY VS2DX...
CASE 850M WT CRAWLER DOZER (A64277)
CASE 850M WT...
