Front Knuckle seal
/ Front Knuckle seal #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
Does the front knucle seal usually require a bearing replacement? I am going to repair a badly leaking seal and notice some play in the l\f knuckle and wonder if the bearings are worn ? Is this is difficult or rather easy repair ,its a 336d
Thanks !!
/ Front Knuckle seal #2
I have changed the seal on my ym2002 but it is a little different than yours. I did not have to replace bearings. I think on hand inspection would be the best determining factor. You may have a manual. Will try and post pictures on a JD 950. Suspect it is real close to your 336.
/ Front Knuckle seal #3
Usually, if you just have a leaking knuckle seal, you will not need to replace the bearings. But if your bearings get loose it can cause the knuckle seals to leak just by letting them wobble around. We have the 336 4wd section on our website now so you can sort of see what it looks like inside (links below).
Internal
Yanmar Tractor Parts: 4WD INTERNAL
external
Yanmar Tractor Parts: 4WD EXTERNAL
/ Front Knuckle seal #4
Hey Aaron is that 336D the same as a 3810D they look the same?
I have one side that's leaking a little 90wt out of the bottom also.
/ Front Knuckle seal #7
I replaced the seal in my 3110D about the same as the 336. I didn't replace the bearing.I did remove the gears from the housing. Mine had shims where you take the gear housing cover off
/ Front Knuckle seal #8
I too had a bad leak on one side of my 3110D. I replaced the seals and no leaks anymore. And I too have some play in the wheel. I've been told that a little play is good and it should be within 1/8" to 1/4" at the top of the tire. Usually a warn out bearing makes an audible sound (obvious) and you can feel it too when you spin the tire by hand.
Pay attention to where you pull the shims out as they are essential in keeping the two drive gears aligned.
I assume you mean the bottom cover, Idid not see any shims,should there be ?
/ Front Knuckle seal #11
You probably haven't taken that apart and don't need too unless trouble is showing there.
/ Front Knuckle seal #12
It would have been difficult to replace the seal had I not taken mine apart
Thanks for the info, I have inspected the entire assembly, I appreciate the info and am replacing a seal and a sleeve on both sides.
my knuckle is just a little different than the one pictured though,its fairly straight fwd repair
Preston from CT~
2011 TAKEUCHI TB153FR EXCAVATOR (A65056)
2011 TAKEUCHI...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
PORTA POTTY (A68842)
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2017 BOBCAT E50 EXCAVATOR (A65056)
2017 BOBCAT E50...
