Loader Front End Loader Rubber Edge Strip?
/ Front End Loader Rubber Edge Strip? #1
DSM
PA
Kubota BX22
Does anyone know if a non-metallic edge strip is available for the FEL? I would like to be able to clear snow from our colored concrete pad without marking it. I have a BX22.
/ Front End Loader Rubber Edge Strip? #2
Not sure this would work on a FEL lip, but on snow plows a piece of conveyor belt from a rock quarry or a rubber mat for horse/cow stalls works well.
My concern on a FEL is how would you attach it so that it would not get torn off.
Roy
/ Front End Loader Rubber Edge Strip? #3
I used a strip from a horse stall mat and installed it on my backblade. I sandwiched it between the blade and cutting edge, exposing about 3" of rubber...works great! I thought about doing something similar to the FEL but I think it would limit what I can use the FEL for. You could probably come up with a light-duty arrangement using some good clamps and a support bar for the rubber.
/ Front End Loader Rubber Edge Strip? #5
Fall Line makes polyurethane snowplow cutting edges and they also have a bucket edge. This link should get you to the right web page FallLine Corporation | Specialists in Urethane Technology and Manufacturer and Distributor of Custom Molded Products and Ski, Construction, Snow Removal, and Sports Recreation Industry Products
I have a concrete paver brick driveway and used a section of their polyurethane cutting edge to make custom protective caps for my snowblower skid shoes. After three years of sliding over paver bricks, concrete, and asphalt, there is very little wear. The folks at Fall Line were very helpful when I called and there were no problems with the billing or delivery.
I hope this helps.
/ Front End Loader Rubber Edge Strip? #6
looks like there is going to be a lot of drilling involved no matter what method you choose, so maybe just come up with a easy replaceable cutting edge or maybe purchase the bx bucket expander and drill that instead of your loader bucket
/ Front End Loader Rubber Edge Strip? #7
Thanks for the great ideas and information. The commercial strip might not be too difficult to install although I can do the welding for c-and-a's slick arrangement.
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
John Deere 24in Backhoe Bucket (A65640)
John Deere 24in...
25 Traffic Cones (A65583)
25 Traffic Cones...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2023 SolarTech Silent Advisor FD-304 Towable Solar Speed Limit Board (A64553)
2023 SolarTech...
